Old Nov 19, 2011, 08:43 AM
zup
United States, PA, Oakdale
Originally Posted by PLMS View Post
I think he meant he added 1/4 inch on the back of the retract mount to tip it forwards more. Could be wrong though...
right. i got the gear raked farther forward. it didnt change the AOA.
zup
zup is offline Find More Posts by zup
Old Nov 19, 2011, 10:03 AM
Making a Dynam Razorback Snafu
Tartago's Avatar
Joined Apr 2006
zup
Anyway. After a frustrating set of crashes 18 months ago and a lenghty repair, today I finally got a couple of decent flights.
I didn't know how powerful this motor is! She took off in less than 15 feet.
I still needed to add 15g of ballast to the nose to balance.
Since I changed to electrics retracts with plastic trunions, the issue now are the wobbling legs. I will need to change the piano wire with something more sturdy.
I really like this plane, bus she is a beeach!
Strange enough, on landing, I reduced the motor to less than 1/4 thr and the propeller stopped.
Video coming soon.
Tartago is online now Find More Posts by Tartago
Old Nov 19, 2011, 11:34 AM
Tartago's Avatar
Joined Apr 2006
Re-maiden
As promised:
Today's video of the re-maiden flight.
Hyperion FW-190 re-maiden (3 min 5 sec)
Old Nov 19, 2011, 09:38 PM
Tank Girl
tankgirlfuzzy's Avatar
Western Washington
Joined Sep 2008
Less Amps with the MAS 3 blade ?
Not what I would have guessed, good to know though as it may mean I'll need to run a 13" three blade MAS with my 950kV motor...
Yes, but only by a little. The two blade was pulling about 49-51 amps, while the three blade was pulling about 46 amps. This is with a 4s, and depending on the battery, I was getting in the range of 720-790 watts. My motor is the Turnigy SK 3548-900. Tach readings with the three blade was 9720 rpms, which is really good. That should give me at least 70 mph in the air.
I'm assuming you'll be using the 13" with a 3s system? Unless yours can handle much higher amp draw?
tankgirlfuzzy is offline Find More Posts by tankgirlfuzzy
Old Dec 02, 2011, 01:50 PM
zup
fan unit
a buddy of mine used the fan and spinner from a flyzone 190. the diameter was smaller then the hyperian but he glued strips of styrene to the blades.
zup
Old Jan 11, 2012, 06:47 AM
Looking4Grass in AZ
Afraidtoregister's Avatar
United States, AZ, Mesa
Joined Feb 2011
I'm pretty sure that's supposed to be a radiator for liquid cooling, not a fan for air cooling.
Afraidtoregister is offline Find More Posts by Afraidtoregister
Old Feb 20, 2012, 02:42 AM
Gamerjoe's Avatar
United States, CA, Diamond Bar
Joined Jul 2011
Prop Spinner?
I just finished building my FW190, but the prop spinner has me stumped. It does not have a collet, or any other obvious way that I can see to mount this on the 5mm motor shaft. Is there something that I am missing?
Gamerjoe is offline Find More Posts by Gamerjoe
Old Feb 20, 2012, 03:01 AM
Martin - AKA mr.sneezy
PLMS's Avatar
Adelaide, Australia
Joined May 2004
Got a photo of what they gave you ?
PLMS is online now Find More Posts by PLMS
Old Feb 20, 2012, 03:41 AM
Gamerjoe's Avatar
Joined Jul 2011
Sure, here is what they gave me...
The long nut has a large inner thread that is very course, and it also has a fine inner thread for the spinner bolt to attach into. I have 6 various collet adapters for electric motors that have a 5mm shaft, but they all have a finer thread than what the spinner nut has.
Old Feb 20, 2012, 06:50 AM
PLMS's Avatar
Adelaide, Australia
Joined May 2004
I just measured the one they supplied me (looks the same), and it's a M6 metric inside thread (6mm diameter with 1mm thread pitch). Hope that helps match it up.
Martin
Old Feb 20, 2012, 08:36 AM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
I think the newer Hyperion collets are drilled and tapped for spinner hold down screws.
http://www.allerc.com/hyperion-extra...m6-p-1665.html
http://www.allerc.com/props-prop-ada...s-c-36_61.html
Email or call AlleRC they can help you out.
TripleW is offline Find More Posts by TripleW
Old Feb 20, 2012, 06:11 PM
Gamerjoe's Avatar
Joined Jul 2011
Thanks for the help guys!
Do you know if I should get the long, or the extra long on the M6 collet adapter?
Old Feb 21, 2012, 02:14 AM
PLMS's Avatar
Adelaide, Australia
Joined May 2004
I would just buy both, and chuck the less suitable one in the spare parts box
Old Feb 21, 2012, 01:20 PM
Gamerjoe's Avatar
Joined Jul 2011
I called the hobby shop and was told that the Hyperion spinners need the Extra long 6mm adapter. Once I receive it, I will confirm.
BTW... the prop fan piece that glues into the cowling was very brittle on my model, and it broke into many pieces when I tried to bend it a little. I went ahead and ordered the Parkzone FW190 cowling on ebay for $5.00, and when I get it I am going to cut out the propr fan portion and modify it to fit.
Old Feb 21, 2012, 02:40 PM
Gamerjoe's Avatar
Joined Jul 2011
Does anyone know of a way to get the camoflauged wing covering material? I scraped a wing tip on my first landing and it tore off a couple inches of the covering. For now, I have just used some clear packing tape to seal up the hole.
Global's Focke Wulf FW-190 ARF electrified?? tnsfrk Electric Plane Talk 17 Mar 23, 2002 07:46 PM
Jamara 1/12 FW-190 Haldor Scale Kit/Scratch Built 18 Jan 31, 2002 01:45 PM
Jamara 1/12 FW-190 Haldor Electric Plane Talk 0 Aug 01, 2001 04:59 PM
Glow to Electric Setup for a Pica FW-190 russcher Scale Kit/Scratch Built 2 Jul 09, 2001 11:10 AM
PICA FW-190 First Flight ArgueRed Scale Kit/Scratch Built 13 May 21, 2001 09:41 PM
