Old Sep 21, 2008, 12:32 PM
duhh is offline
Find More Posts by duhh
Joined Dec 2005
current limitting with just one adc input ??
can this be done ?? Idea`s are welcome ..
The problem is, I have the vref- and vref+ already set and I dont them to get to close to each other as I use adc for controlling the amount of power to the motor and I dont want that conversion to be to sensitive. Also as te titel did allreay mention. I have only one analog or digital input/output pin left
on my pic16F88.
I`m thinkking about using the piece of cable from the battery to the negative connection of the controller as the shunt. So I only need one measuring point as the other point would just be the ground. but I`m concerned about precision.
Well thinking about it, I just need to calculate.. vref- is ground 0 and vref+ is 5 Volt so 5 Volt : 255 = 0,01960784313725490196078431372549 volt precision
lets say I want about 10 amp acurracy than 0,01960784313725490196078431372549 x 10 = 0,1960784313725490196078431372549 Ohms of cabe resistance is what i need ... and it would than be capable of measuring up to 255 x 10 = 2550 Amp. I have no idea if this is possisible .. and also connectors and stuff needs to be the same resistance everytime its reconnected ..
Anny way, anny thoughts, idea`s or experiences are well apreciated.
measuring voltage only at one point.
duhh is offline Find More Posts by duhh
Old Sep 21, 2008, 12:39 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
Current sense amp. I like max4173. Easy as pie.
Comatose is offline Find More Posts by Comatose
Discussion Airliner--where can I place with just one Duct Fan? jascamera Electric Ducted Fan Jet Talk 8 Feb 17, 2007 02:32 PM
Coming to terms with letting one go.. Andy W Electric Plane Talk 47 May 07, 2003 11:16 PM
Can I use just one type of connector??? Roger_One Power Systems 33 Mar 26, 2002 05:32 PM
Mini IFO first flight , just one silly question though... Jeremy_D Parkflyers 8 Jun 01, 2001 07:23 PM
Just one of those days... Sal C Electric Plane Talk 5 May 13, 2001 11:18 PM
