Joined Oct 2005
Most people that dribble about Lawmate quality issues have never used them.
In my experience they are better than anything else out there... The saw upgrade racewoods are also good. I have 6 LM Rx's and 5 Txs with zero problems, hundreds of fights and a pb of 22km. List looks good, you have done your research. Do a little reading on using Dragonlink with 1.3 video and you may consider ezuhf or the TSlrs. Apm2.5 is an awesome bit of kit but just be prepared for a lot of reading and setup. There is so much to learn and solve with FPV so you want to just get a basic no osd setup working first.. Then add gear as you sort the problems out. Chris. |
Joined Apr 2013
Thanks Nut,
I will be using most all of the features of the ADM stuff. I used a simple KK setup to get the Tricopter flying and tuned. I feel it is best to spend the effort getting the mechanics right prior to trying to fix basic airframe/aerodynamics issues with software. Now that it's flying I want more advanced features, like position hold, RTH, hands off route flights, etc. Most of the reviews I've read have spoken quite highly about lawmate, the only exception is that their more powerful tx's (1W+) have a tenancy to burn up if not very well ventilated which can be a bit of a difficulty on a multi. Thanks again! |
Joined Oct 2005
Yes the 1w txs do get hot, better heatsink or fan solves that easily.
But.. Stay with the 500 you have listed, a 1w can cause you GPS lock grief unless you can get good separation. My 22km was done with a range video vtx running about 600mw. As youll learn Range and Clarity gains are mostly made on the receiving end of the video :-) |
Joined Apr 2013
Thanks Nut,
I already got some similar advice on the FPVlab forum about focusing on the Video Rx. For now I'm starting with my tricopter so range is not a huge issue. Once I go to my plane I may look into a 14db+ patch antenna and diversity system. For now I'll get lots of goggle time. |
| Thread Tools | |
| Discussion ASP 180AR Two Stroke Glow Engine (from hobbyking) initial setup of needles and plug | martin555 | Engines | 18 | Apr 29, 2013 12:15 AM |
| Found Looking for multi with FPV setup | ocso295 | Aircraft - Electric - Multirotor (FS/W) | 2 | Mar 28, 2013 08:10 AM |
| Sold Complete Immersion RC 5.8ghz FPV setup brand new | Johnnymeg | FPV/RPV - Equipment and Vehicles (FS/W) | 6 | Mar 27, 2013 04:59 PM |
| Discussion Initial flight setup instructions for my techone 330 extra or any plane | finguz | 3D Foamies | 0 | Jan 03, 2013 03:33 PM |
| Help! Buying FPV gear.. need advice on initial setup | neo__04 | Video Piloting (FPV/RPV) | 22 | Mar 08, 2012 10:25 PM |
