Old Jan 31, 2002, 06:54 AM
France
Joined Jan 2002
Cumulus 2000 vs Filip 400
Hi,
I am considering buying one of these and am looking for a bit more info to help me decide which.
My questions are:
How easy are they to fly? I am a relative beginner having only flown a 40 trainer (with ailerons).
What are the (best) motor / gearbox / prop options for each?
What are the battery options for each (capacity/cells)?
How easy is the Cumulus 2 piece wing to assemble on field?
Plus any other useful info on them.
muns is offline Find More Posts by muns
Old Jan 31, 2002, 07:03 PM
Crash test dummy
Svengali's Avatar
Atascadero, CA
Joined Dec 2000
I've flown my Cumulus 2000 twice now, and it's pretty easy to fly. It handles turbulence pretty well, and can fly slowly. I did get some wing flutter on my second flight, so it doesn't like higher speeds very much.
I'm flying the recommended setup from Hobby Lobby, which is a speed 480, with 8 cells and a cam 11-8. Definitely no problems gaining altitude.
The wing is very easy to assemble on the field. Two wing joiner pins, two screws, and you're done.
Take a look at my cumulus page for some pictures if you're interested.
Svengali is offline Find More Posts by Svengali
Old Jan 31, 2002, 10:10 PM
MikeC's Avatar
Albuq, NMex USA
Joined Jan 2001
If you don't mind flying at 10 oz. sq/ft put a geared Kyosho AP29L in your Cumulus. Close to vertical for as long as you like. The motor is about an ounce heavier but you will need heavier batteries than 600AE's. 7- AR800s or CP1300s.
MikeC is online now Find More Posts by MikeC
Filip 400 RG vs. K&A Odyssey TheDanAbides High Performance 0 Oct 13, 2004 04:33 PM
FVK Trendy 480 vs Cumulus 2000 Bob81 Electric Sailplanes 8 Nov 09, 2001 08:43 PM
Junior Sport Plus vs Cumulus 2000 Magna Electric Sailplanes 9 Oct 24, 2001 05:09 PM
Speed 400 6volt vs Speed400 Race vs Rocket 400 for SS Pro erashby Power Systems 1 Aug 06, 2001 08:52 AM
Astro 05 vs Speed 400? Eric H Beginner Training Area (Aircraft-Electric) 11 Jun 13, 2001 07:17 AM
