Old Feb 16, 2014, 03:16 AM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Build Log
PP1 a Simple to build, Easy to fly design
The PP1 design is based on an old paper plane I used to make as a kid, it was simple to fold and one that would always go well..
below is the folding sequence for the kids model
It came up when talking with my flying buddy about the old days and I thought lets do it from foam..
So sketchup got running and the model was quickly drawn up..
The first build was sized to work with the 1811-2900 motor indoor setup we have been using.. a wing of 200 to 225 sq inches area has been giving us a reasonable final weight model so that's what we used
The model is a KFm2..step on top design.. top step now shown coloured yellow... its not a 50% step, its at a lesser %age.. more a step for strength than effect.
there is a sketchup file in the zip, this will let you scale the model easily and quickly.. its saved from the latest version of sketchup , so if you need and older save let me know
davereap is offline Find More Posts by davereap
Old Feb 16, 2014, 03:28 AM
davereap's Avatar
Joined Feb 2005
EDIT note the first build has been simplified and modified... see post 69 for the new simpler build.. the V shaped body below was replaced with a 2 layered laminated spline, stiffened with pallet strapping..
and the top step shape was revised for a bit more wing stiffening..
For the first model we used 3mm depron.. at a 16" span size
The strapping on the depron is only across the span at the step, tape is used as décor and all control surfaces are fully covered to make them stiff.. wing tip fins and leading edge are also covered to add stiffness and strength.. hinges are all full length clear tape,
horns are from dental flossers, paper clips for the Z bends and CF pushrods
On the depron model I used EPP for the nose block, this is much better for spreading the impact and landing stresses
depron is lighter but EPP gives better bounce.. If you can get some then 5mm EPP is best for indoor bumps and bashes
depron with tape is however quite tough, its already had multiple bangs and is perfectly fine..
My first depron build lasted a season before it started looking tatty and bashed, my flying buddy's one is still being used, but he flies it more gentle than I do, he just likes to cruise around
The depron models flight proved so nice, both fast and slow, that Ive now made a second bigger version in 5mm EPP.. this is at 19.5 span
NOTE all the construction pics were taken when making the second bigger EPP build.. the build method is the same for both.. the build is now simplified, take a look at the new revised lines..
Dihedral angle ..the target is 20 degrees, but somehow my building hasn't achieved this, I must have flattened mine out as I stuck it all together... start with the 20* fold down but don't worry if you loose some... my first 3mm depron build flew at 16...my EPP build is only 12..My flying buddies small version is at 20.... and my latest 24" one was started with a 25* fold but has ended at 20...
So its not critical.. we havnt noticed any significant difference in flights, they are all easy... and capable...
Old Feb 16, 2014, 03:32 AM
davereap's Avatar
Joined Feb 2005
A video of the small one...
PP1 paper plane scale up... a really good flier with very fast responses .. its capable of high speed and wild aerobatics, so much so that I am having to lower the rates to fly it...
at the slow speed end its just the opposite , with its dihedral its very stable and easy ...using low power and low rates it floats around nicely ..
my buddy loves it , he prefers the nice and easy fliers and this does the job well
PP1 Maiden flight (4 min 59 sec)
Old Feb 16, 2014, 03:36 AM
davereap's Avatar
Joined Feb 2005
here are the larger 19" sizes lines , the sketchup file and a pdf for the larger version
to resize this use the tape measure tool in sketchup and go across the span.. enter the new span in the measurements box and ok the resize
EDIT I have ended up with 17" as being an optimum size for indoor flight.. a 17" fitted with a 17gm hyperon z1705-14 is a very good setup
Old Feb 16, 2014, 03:54 AM
davereap's Avatar
Joined Feb 2005
16" setup 3mm depron build and 5mm EPP build
1811-2900 kv motor on 2s... 300-500 lipo.. now flown mostly on a 500 and a 1000 2s lipo for longer flights... this model easily handles the bigger battery
GWS 6x3 prop..
6A ESC... micro orange RX with 2gm servos for the lightest setup ..micro plugs and sockets.. which are still working fine after a years bashing about
or
any light weight RX standard pins, with 4.3gm servos standard plugs..
AUW 115 gms with a 300 lipo for a 2.7ozsqft loading
Old Feb 16, 2014, 03:58 AM
davereap's Avatar
Joined Feb 2005
19.5" Setup 5mm EPP build
robot birds 15gm 2300kv motor or similar
GWS 8x4.3 prop
12A ESC..
standard orange 6ch RX ..
or http://robotbirds.com/catalog/produc...oducts_id=5883
3x 5gm servos.. all fairly light gear
AUW 6.8oz with a 500 2s lipo for a 3.2ozsqft loading..
Old Feb 16, 2014, 05:48 AM
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Good One Dave !!!
gpw is offline Find More Posts by gpw
Old Feb 17, 2014, 10:36 AM
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Nice Dave. I was thinking about this exact and last week. When I a boy I had bunk beds and one of those hang down tile roofs above it. That was where I kept my paper airplane hanger. Anyhow last week while outside with the kids I was trying decide what would be a good trainer that would be easy to fly and could handle hitting the ground. I think you nailed it, I will get one flying this spring and see how the kids like it
Wilfor is offline Find More Posts by Wilfor
Old Feb 18, 2014, 03:32 AM
davereap's Avatar
Joined Feb 2005
Fly it on low power with reduced control movements and its slow, very stable and easy to fly ..
The small one , I first built, is for indoors... for outside and training go bigger, go up to a 22 or 24 inch span using 6mm depron.. Use a Blue Wonder 1300kv with 3s or a 1700kv with 2s or any other similarly cheap motor up to about 100W with a 12A esc and 5gm servos..
Bigger always results in a more docile model, so you can go as big as you fancy... however going bigger requires slightly more expense on the build and on the gear.. so for training I would keep it as cheap as possible..
The other simple fun model I similarly recommend for learning on is a Nutball , again build at 24", that also is also very stable and easy at low speeds and low movements.. the nutball is simpler, using 3 ch, rudder elevator and motor ..the PP1 uses all the 4 channels so gets you used to having both ailerons and rudder to steer with..
I love the nutball but I think the PP1 from my point of view has it beat, better fast rolls and easier hover .... neither will knife edge easily...
and later powered up a bit both can be highly aerobatic
Old Feb 18, 2014, 11:16 PM
davereap's Avatar
Joined Feb 2005
here is the lines plan for a 24" size.. its suited for blue wonder motors or similar, something up to and around the 100W size
EDIT I well overpowered mine..lol with a 150W axi motor that was going spare.. flown on 3s with a 9x5 prop its great
don't be frightened of using a bigger motor the throttle will control all the extra power... more power is more fun.... lol
Old Mar 03, 2014, 04:13 AM
United Kingdom, England, IOW
Joined Jun 2011
Thank you dave for another grate thread
kieranb is offline Find More Posts by kieranb
Old Mar 07, 2014, 02:51 AM
davereap's Avatar
Joined Feb 2005
The 19" version was flying well... then I hit a roof beam and the motor stopped working... I prefer the smaller version for indoor tight spaces.. that is the 16"er, it needs a lot less airspace...and being lighter feels nicer..
the 19 is ok in our hall, but with more power I got it up too high, too fast, and bang it was done for the night...
I had to swap the motor... it runs with no load but wont run with a prop on it.. I suspect the wiring might be only just holding together, a poor joint or such.. but cant be bothered to sort it at the moment...Ive too many motors ,swapping is easier..
EDIT while the 19 is flyable indoors it is a fraction too big for me .. I have settled on a 17" EPP version using a 17gm motor .. and a 16" EPP version that uses the 1811-2900 motor for my indoor sessions..
Old Mar 14, 2014, 12:04 PM
davereap's Avatar
Joined Feb 2005
An indoor session had two of the smaller depron versions flying together..
watch in HD full screen for best views
Depron PP1 indoors (5 min 57 sec)
Old Mar 14, 2014, 01:28 PM
davereap's Avatar
Joined Feb 2005
EDIT out side the 19" EPP version is great... watch in HD full screen for best views
and now by early 2015.....Ive also made 24 and a 30" span versions.... both truly lovely fliers
Depron PP1 19 EPP version outdoors (8 min 5 sec)
Old Mar 14, 2014, 02:04 PM
maurice076's Avatar
United States, MI, Warren
Joined Aug 2011
Pretty cool Dave, may have to throw one together for nostalgia if anything
maurice076 is offline Find More Posts by maurice076
Question I want to build a scale rc kit that's easy to fly Downtownhobby Scale Kit/Scratch Built 9 Feb 07, 2014 10:58 AM
Discussion Slow & Easy to fly first build & equipment BuckFuller Beginner Training Area (Aircraft-Electric) 17 Oct 09, 2013 06:03 PM
Discussion BowStick - Basic design, Simple to build, Easy to fly and Absolute fun, fun, fun. DaDesign Foamies (Scratchbuilt) 237 Sep 12, 2013 07:57 PM
Build Log EYE-PLANE: Easy to build/fly AP designed around EYEPOD mount, VIDEOS & FREE plans! jarel design Aerial Photography 363 Mar 01, 2012 12:28 PM
Build Log Simple Nieuport 28 - design-build-fly by GPW, MS, Jasta_66, stanordave, et al segraves Foamies (Scratchbuilt) 143 Aug 09, 2008 03:03 PM
