Old Dec 16, 2013, 08:48 AM
2dogrc's Avatar
WHere Flight Was Born, North Carolina
Joined Apr 2005
Best Multi Rotor Motors with Lifetime Warranty
Dualsky has produced a line of quadcopter motors. These motors have been tested by Dualsky and myself! The 40mm pancake motors as they are often referred to, provide very efficient thrust at low Kv's for large props. Compared to similar 26-30 mm 12 pole motors, these are more powerful and quite!
I have run both these size motors on quads you may be know, such as the QAV 500. Our 4010 motors are pushing 100 flights already with no failures or damage!
In each box you get a prop mount as well as a "X" mount. The top of the bell has 4 threaded holes if you prefer to mount your propeller directly to the motor.
Xm4010 Specs:
KV: 880RPM/V
Weight: 78g
Diameter: 40mm
Length: 25mm
Diameter of Shaft: 3.175mm
Mounting holes pitch: 16/19mm Slots,
Poles: 24, 28
Idle Current(Io) @10V: 1.8A
Resistance(Ri): 44mOhm
Cruising power[8 mins]: 193.92W
Bursts current[15s]: 31.76A
Peak power[15s]: 352.59W
Recommended ESC: XC3012BA Setup 1 (No. of Cell, Prop.): 3S, 9x5 - 11x5
Max. weight of 4-rotor copter: 1.94kg
Max. weight of 3D models: 0.65kg
Memo: 2KG 4-rotor copters, 480 class airplanes
XM4005 Specs
KV: 840RPM/V
Weight: 53g
Diameter: 40mm
Length: 20mm
Poles: 24, 28
Idle Current(Io) @10V: 0.8A
Resistance(Ri): 123mOhm
Cruising power[8 mins]: 102.68W
Bursts current[15s]: 16.85A
Peak power[15s]: 187.03W
Recommended ESC: XC1812BA Setup 1 (No. of Cell, Prop.): 3S, 8x5 - 10x5
Check these out for your next project!
2dogrc is online now Find More Posts by 2dogrc
Site Sponsor
Latest blog entry: 2dogrc and 2dogs Flying FPV
Discussion Afro Slim 20Amp Multi-rotor Motor Speed Controller (SimonK Firmware) digaus Multirotor Electronics 23 Feb 23, 2015 10:20 AM
Found Hobbyking KK2.1 Multi-rotor LCD Flight Control Board With 6050MPU And Atmel 644PA jmdlcar Aircraft - General - Radio Equipment (FS/W) 4 Dec 13, 2013 03:03 PM
Discussion What is the best way to get into Multi Rotor? Newbie COMike93yj Multirotor Talk 29 Nov 25, 2013 10:48 AM
New Product Motors for multi rotor copters Airrover Product Announcements 0 Oct 17, 2013 03:57 AM
New Product New Line of Servos, With Lifetime Warranty! 2dogrc 2DogRC 0 Jul 14, 2012 08:27 PM
