Closed Thread
Old Nov 12, 2013, 08:02 PM
United States, CA, Lompoc
Joined Nov 2010
XFLR5 to CAD?
I had an awesome plugin that went from solid works to xflr5. (.avl/.wpa)
I recently lost my student license for Solidworks (until I go back to school) and I would like to use sketchup...
Does anyone know of a way to easily import, convert, or accurately trace an XFLR5 aircraft to ANY CAD software without having to rebuild the whole thing?
I have done it the other way around, but never XFLR5 to CAD...
Thanks a ton fellas!
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Nov 13, 2013, 10:20 AM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
What were you using to go from SW to XFLR5? I assume it was also an educational license?
Greg
gkamysz is offline Find More Posts by gkamysz
Old Nov 13, 2013, 10:24 AM
Joined Nov 2010
Yes it was. I know (or think) it was a plugin?
It couldn't do an entire aircraft, but it could do pieces, ie: wing, fuse tail.
I am looking into using sketchup, although I found SW and Autodesk to be easier to use systems...
Old Nov 13, 2013, 02:16 PM
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
I would like to know more about the plugin you were using to go from SW to XFLR5? I've never heard of such a plugin...
samc99us is offline Find More Posts by samc99us
Old Nov 13, 2013, 05:57 PM
Joined Nov 2010
Ill try to track it down. I'm pretty sure xflr files are just text files with coordinates. I know when I saved as an .avl it came up with a progress bar (for about 5 seconds). If you cliked on the file out of xflr it just opened in notepad and was a bunch of text...
Do you guys know of anyway to go from xflr5 to any cad program? Or is Re-making it the only way?
Old Nov 14, 2013, 12:03 AM
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
The only thing that i have ever been able to use from XFLR5 is the .dat export of airfoils from the Direct Foil Design section. I do have to agree, it's a shame it will not import/export the mesh (yet ). There seems to be some discussion to that end over on the Sourceforg / XFLR5 site. So maybe stay tuned... or better yet, get involved.
Quick61 is offline Find More Posts by Quick61
Old Nov 14, 2013, 12:08 AM
Joined Nov 2010
Awesome! Thanks for the info.
Wings are fairly easy to do IMO. With just lifting between airfoil sections.
I suppose I will just do the same for the fuselage.... After all, XFLR 5 shows each section when you design a fuse... I suppose you can just "snip" or screenshot the sections and just loft it in CAD.
Closed Thread
Cool DesignSpark Mechanical 3D CAD (free CAD) kdahlhaus CAD/CAM 10 Apr 17, 2014 06:27 PM
Discussion XFLR5 Problems PAL10 CAD/CAM 2 Nov 06, 2013 05:25 PM
Discussion XFLR5 canard help p901P901 Modeling Science 3 Aug 10, 2013 02:44 PM
Discussion Confusing Results in XFLR5 bwill6 Hand Launch 11 May 08, 2013 03:27 PM
Discussion XFLR5 Windows 8 ThomasLee Hand Launch 13 Jan 10, 2013 06:31 PM
