Old May 09, 2013, 02:10 AM
Joined Aug 2006
DS-20 Hyperion servos with the Beastx
Hi,
does anybody know anything about the frequency and neutral pulse width of Hyperion ds-20fmd and ds-20gmd servos?
Are they copies of other brands?
Thx.
jackheli is offline Find More Posts by jackheli
Old May 09, 2013, 03:34 PM
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
since no one answered, try 1520/333
fly for a minute, check the temp. If the servos are hot drop the 333 to the next one down. Repeat process until the servos are ok to fly with.
for cyclic 200hz
pitchp is offline Find More Posts by pitchp
Old May 09, 2013, 04:28 PM
Joined Aug 2006
for cyclic 200hz
Good idea. Will do. Thanks.
Old May 09, 2013, 07:33 PM
No Longer Active
pitchp's Avatar
Joined Aug 2010
anytime!
Old May 10, 2013, 10:08 AM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
The Hyperions won't like that high a setting, I would start with 165 personally
MikeHRC is online now Find More Posts by MikeHRC
Old May 10, 2013, 02:31 PM
wlee1017's Avatar
Joined Jul 2011
Hyperion Altas digital servo can accept frame rate from 20Hz to 270Hz. 333Hz frequency too high.
http://media.hyperion.hk/dn/at-ser/ATLAS-MAN-EN-PG2.pdf
wlee1017 is offline Find More Posts by wlee1017
Old May 10, 2013, 03:42 PM
Joined Aug 2006
Excellent info. VERY much appreciated.. I'm set.
Cheers.
Old May 10, 2013, 09:19 PM
No Longer Active
pitchp's Avatar
Joined Aug 2010
jack (your in luck) ask this man since he has/had one with the beastx. Saves you from testing which setiings works best.
http://www.beastx.com/archive/index.php/t-597.php
Old May 10, 2013, 09:48 PM
Joined Aug 2006
Looks good. Setting it up at low frequency.
Thanks all for the advice.
Old May 13, 2013, 05:00 AM
mattox's Avatar
peoria,az
Joined Sep 2009
I run the Hyperion at 200hz on cyclic and 1520/333 on tail for over 300 flights now. The servos can handle it no issue. No reason to run them at a lower rate. Performance is not an issue. I beat on my birds severely.
Mattox
mattox is offline Find More Posts by mattox
Old May 26, 2013, 09:46 AM
Never trust laughing dolphins
Joined Feb 2011
I really would advice starting low so it won't damage the servos at the very first try. Then just stick with the setting that performs best, without a lot of servo buzzing or chatter and temperature raise. Starting too high can destroy a servo, even when most servos will be compatible with 200hz cyclic and 1520/333hz for tail.
PHMX is offline Find More Posts by PHMX
Old May 26, 2013, 04:40 PM
No Longer Active
pitchp's Avatar
Joined Aug 2010
Mattox
PHMX this is why I suggested him to try the top settings first, because I know that there have been several reports people are using these settings. So to save the man some time at trying out different settings. I thought I'd offer the most commonly used settings. But I did also tell him to check all the servo temps after flying for a minute to make sure the servos are not hot and that they are ok.
Old May 31, 2013, 02:27 AM
Joined Feb 2011
I can relate to that, but without firsthand experience I wouldn't put blind fate in a forum post assuming it will work fine when not knowing the actual specs. I am sure we don't have to question every such post you refer to and as such it wasn't really a comment to disagree, but I see things like this go wrong from time to time because people start high instead of low. Starting high can potentially destroy a servo, why would you take such a gamble first when you can start low and keep things working?
Same goes for gyro gains, motor rpm, blade pitch and the list goes on. All I'm saying.
Old Jun 01, 2013, 07:16 PM
No Longer Active
pitchp's Avatar
Joined Aug 2010
Old Jun 07, 2013, 05:45 PM
mattox's Avatar
peoria,az
Joined Sep 2009
Empire RC should tell you the same settings. Got another 50 flights on these servos not changing a thing. So now I'm at 350 flights no problems. I don't baby my Helis either.
Mattox
For Sale HYPERION ATLAS DS 20X SMD CORELESS DIGITAL SERVO FOR YOUR 550/600 Heli's NIB! mygsx Aircraft - Electric - Helis (FS/W) 1 May 16, 2013 03:36 AM
Discussion Hyperion Atlas DS 20 Standard Size Servos Thread RcSuperSales-Net Large Electric Helis 109 Dec 13, 2010 08:18 AM
Wanted Hyperion Servos DS 20 FMD and DS 20 UMD cbarnettone Aircraft - General - Radio Equipment (FS/W) 0 Jul 18, 2010 08:46 AM
Discussion XMHobbies G401B HH with HYPERION ATLAS DS 20 GMD?? jcervantes11 Electric Heli Talk 0 Mar 02, 2009 12:56 AM
Poll Hyperion Atlas DS 20 Standard Size Servos OFFICIAL Thread RcSuperSales-Net Electric Heli Talk 24 Jan 31, 2009 01:07 AM
