Old Apr 07, 2013, 06:46 PM
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
Belt Drive with an outrunner.
I was sitting around looking over some timing pulleys and belt ,,when it dawned on me ,, why don't I just use the body of the outrunners my bigger pulley, or ..depending on the who it's the smaller one..
Anybody ever come across this?
It cant wander ,,it will just track of the pully.. make alignment a breeze.
more coffee is offline Find More Posts by more coffee
Latest blog entry: Hi!
Old Apr 07, 2013, 07:46 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
The belt drives we used in airplanes are toothed belts with "gear" pulleys. Nothing is smooth - it would slip too badly.
They're more like timing belts in your rice burner.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Apr 08, 2013, 05:48 AM
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
It should work as long as the motor can is perfectly parallel with the timing pulley, if it isn't the belt will track to the edge of the pulley flange and quickly wear though. As the diameter of the out-runner can is quite large an even bigger pulley would be required unless a speed increase is needed?
It will need belt tension as well, the supposed advantage of a toothed belt is that minimal tension is normally needed as opposed to V or round belts.
Nick
nick_75au is offline Find More Posts by nick_75au
Old Apr 08, 2013, 08:44 PM
Cheif Bottlewasher
Joined Sep 2005
I thought it might work , wonder how the bearing loads would be
Old Apr 09, 2013, 01:32 AM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
since the can is only mounted to the shaft at one end, and free floating at the other, i would think that any tension on the can would cause the magnets to grind into the wiring.
tsenecal is offline Find More Posts by tsenecal
Old Apr 09, 2013, 08:36 AM
Wallingford, Ct
Joined Sep 2001
Are the bearings up to the side load? Time will tell. It is worth a try.
Al M is offline Find More Posts by Al M
Old Apr 09, 2013, 10:56 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
What the C/L Stunt guys do is add a bearing and former to support the far end of the shaft (they use the firewall as right behind the spinner, at the prop end, to minimize damage from precession).
Andy
Site Sponsor
Old Apr 09, 2013, 07:45 PM
Wallingford, Ct
Joined Sep 2001
I suppose they get away with it, but more than two separated bearings on the same shaft is not considered good practice. I guess things work well enough and long enough on our scale.
Old Apr 09, 2013, 08:42 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
They only have 2 bearings supporting the shaft, the other is supporting the can against the shaft.
Andy
Site Sponsor
Old Apr 11, 2013, 06:55 AM
Norwich, England
Joined Mar 2001
See here:
http://www.castlecreations.com/produ...unt_setup.html
ChrisE is online now Find More Posts by ChrisE
Discussion Seeking 2-3mm wide belt / chain drive ShaKaan Power Systems 3 Jan 11, 2013 12:00 AM
Sold Conley 1.20 4 Valve Belt Drive Cams CADILLAC200 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jan 10, 2013 11:28 AM
For Sale tail drive belts moparren Aircraft - Electric - Helis (FS/W) 0 Jan 02, 2013 09:38 PM
Discussion Belt drive, outrunner powered, 7S lithium Tamiya TXT1!! Heli Mod Man Off-road Cars 12 Aug 12, 2006 09:53 AM
Discussion make an outrunner from an floppy drive. rsx19 Electric Motor Design and Construction 10 May 26, 2006 09:31 AM
