Old Oct 12, 2012, 08:25 PM
United States, TX, Spring
Joined Aug 2012
throttle range setting frutration...
Having problems setting throttle range...
futaba 6j
futaba r2106gf
hurc 40 amp esc
gf2215/15 motor
3 cell lipo
turn Tx on, move it to full throttle, connect battery...
get three tones a pause, then 3 tones again...a couple seconds
then two.
TX is set to plane/acro mode...
RoadkillStewie is offline Find More Posts by RoadkillStewie
Old Oct 12, 2012, 09:08 PM
wizard of odd's Avatar
Australia, WA, Kalgoorlie
Joined Apr 2011
What's the exact problem you are having? Most ESC's are self calibrating, as you have tried above. Try canging the throttle end point adjustment- even to the minimum (-) and maximum (+) value, which should improve resolution.
wizard of odd is offline Find More Posts by wizard of odd
Old Oct 12, 2012, 09:13 PM
Joined Aug 2012
as per docs...
connect esc, motor & rx... turn on tx, set to max throttle...
connect bat...
esc should give tone/beep for each cell...
a pause, then there should be two beeps... at which point
move throttle to minimum which should be followed by a single beep.
I get 3 for bat, a pause 3 more a couple seconds then 2.
I've tried setting max +/- sub-trim with the same result ^
result being throttle range is not set, and hence i have none...
Old Oct 12, 2012, 09:26 PM
Joined Apr 2011
If initialisation is the problem, adjusting the throttle subtrim to a value below zero usually helps (the ESC is not sensing zero throttle). One of my ESC's won't initialise unless the subtrim is set to -55! Some TX's want to have the throttle channel reversed. Try this (without a prop on to avoid blood spillage!) and repeat your sequence.
If the problem is range adjustment, setting the subtrims usually won't do the trick. Adjusting the travel/end point adjustment on the throttle channel can be helpful here.
Hope you get it sorted soon....
Odd
Old Oct 12, 2012, 09:40 PM
Joined Aug 2012
Odd
My guess is initilization... as it doesnt 'act' like it supposed to according to the docs and theres no throttle response at all after the fact.
Old Oct 13, 2012, 12:52 AM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Throttle has to be reversed on Futaba radios! Are you plugged into chan #3? Do you have the rx connector in upside down.
All common problems, I've done each of hem myself - hehe. Worth checking. Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Oct 13, 2012, 06:33 AM
Joined Aug 2012
Think it was the reversal, stumbled into getting it to spin...and worked it out from there.
Help! ESC throttle range setting ronzu Power Systems 4 Oct 11, 2012 04:51 PM
Question Throttle range with set up V1.5.0.51 gweleps Hoverfly Technologies 2 Jul 22, 2012 02:38 AM
Question How to set throttle range with Jeti Spin box ? badbill Power Systems 0 Dec 25, 2007 03:55 PM
Suggestions on setting throttle range? davensocal Electric Heli Talk 6 Apr 25, 2003 11:52 AM
