Old Apr 16, 2012, 10:15 AM
United States, FL, Miami
Joined Aug 2011
batteries in series
Iím thinking about buying two 2 cell batteries instead of using one 4 cell. I just want to make sure that my findings are correct.
25c 1500mah battery = 37.5 amps discharge rate
if i put this battery in series will it equal to 75 amps discharge rate?
Mikep0011 is offline Find More Posts by Mikep0011
Old Apr 16, 2012, 10:19 AM
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Originally Posted by Mikep0011 View Post
I’m thinking about buying two 2 cell batteries instead of using one 4 cell. I just want to make sure that my findings are correct.
No, it will still be 37.5 amps maximum discharge rate.
They need to be in parallel to increase the amperage rating. Then you would have a 2S2P pack. Probably not what you are after.
Ken Myers is online now Find More Posts by Ken Myers
Old Apr 16, 2012, 10:33 AM
Joined Aug 2011
Thanks a lot for your quick response. yeah I'm looking for a 60 amp draw. I'll then have to up the c rating of the batteries.
Old Apr 16, 2012, 10:46 AM
So. Cal.
You do realize that there are no 1500mAh lipoly cells that can sustain a 60 amp draw on a repeated basis without suffering certain damage?
Your best bet at coming close to this goal are the Thunder Power G6 65C packs. They're not cheap but if you need a 60A draw from a 1500mAh pack, they will most certainly serve you better than nearly all other lipolys that are currently available.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Apr 16, 2012, 04:47 PM
Joined Aug 2011
Wouldnt a 45c battery 1500mah give me 67.5 amps?
I found this battery this should give me a little over 60 amps continuous right?
http://www.hobbypartz.com/77p-sl1600-2s1p-40c-2222.html
Old Apr 16, 2012, 06:13 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Do you realize how fast a 1500mah battery drawing 60 amps will be discharged. It will be dead in about a minute and a half. The correct solution to your 60 amp draw will be to increase the mah not the C. You should really be looking at something like a 4500mah 20C battery.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Apr 16, 2012, 06:30 PM
So. Cal.
If you believe the label, yes. Problem is that there is no such thing as 1500mAh pack that can repeatedly sustain a 60 amp draw without suffering irreparable damage. Labels lie, plain and simple.
Glen is absolutely correct (as usual). You need a MUCH bigger battery if you need to sustain 60A draw throughout the discharge, and hope to do so for more than a few discharges.
Mark
Old Apr 16, 2012, 08:33 PM
Joined Aug 2011
Alright I understand, Thanks alot for your help
If intrested there was a couple of factors which had me thinking into going with two 2 cells instead of one 4 cell battery.
1. The 2 cell packs were lighter together, than one big 4 cell. ( so more mah longer flight)
2. The charger I own can only handle 5 amps of charge, but with 4 cell it was 3.5 amps. Thinking a 2 cell can charge faster.
Conclusion: Need to stop being a cheap arse!!
Thanks again!!
Discussion 1 x Parallel and 2 x Series all run in Parallel Battery Question.. topgearuk Batteries and Chargers 2 Apr 04, 2012 02:48 PM
Help! Battery "C" rating when wired"In Series" rabdooley Power Systems 3 Mar 12, 2012 09:29 AM
Help! 2s and 3s batterys in series. Redhood Batteries and Chargers 3 Dec 23, 2011 08:49 PM
Help! Quanum and running batteries in series MiG-3 Reno Rocket Batteries and Chargers 17 Nov 26, 2011 10:03 PM
Question better field battery ;one big 12v or 2 smaller 24 v in series? cmulder Batteries and Chargers 1 Sep 12, 2011 08:40 AM
