Old Jul 26, 2003, 06:26 PM
M.PROTZEK's Avatar
Reidsville, N.C.
Joined Jan 2001
Epoxy for motor mount
I have been using 5 min epoxy to glue the motor mount in my
twister. It seems that the epoxy is brittle and that after 5-10 flights I need to reglue the mount.Could there be a problem with the epoxy.It seems to adhear to the wooden mount well, it does'nt seem to be adhearing to the glass well.Does anyone have any thoughts on this.
M.PROTZEK is offline Find More Posts by M.PROTZEK
Old Jul 26, 2003, 07:02 PM
All under control, Grommit!
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
You could try roughing up the glass a little with sandpaper or a fine file and 30 minute epoxy might also do a better job adhering to the wood as it has a better chance of soaking in a little.
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Jul 26, 2003, 07:06 PM
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
There's also a "flexable" epoxy available.
Can't remember what brand, but it seems that it was Jett 30 min. epoxy.
VP
Viper Pilot is offline Find More Posts by Viper Pilot
Old Jul 26, 2003, 07:07 PM
God is good
Banjul
Joined Jan 2001
One more thing.
The fast curing epoxies always seem to be more brittle than the slow cure stuff.
VP
Old Jul 26, 2003, 07:30 PM
Profiled Interfractionalist
William A's Avatar
United States, WA, Tacoma
Joined Jun 2001
Motor getting warm ?
Epoxy will soften with heat.
William A is online now Find More Posts by William A
Old Jul 26, 2003, 09:34 PM
iva
iva's Avatar
Vancouver Harbour Sp, Canada
Joined Jan 2001
I would use a 5 minute epoxy only if I have absolutely no other choice. It usually cures brittle or rubberey, regardless of a brand.
You can make much stronger joyints with slow cure type-45 mins as my minimum cure time. If you need to reduce the cure time you can always use a hair dryer to heat up the area being glued. That will also produce much stronger joyint.
Zoran
iva is offline Find More Posts by iva
Old Jul 26, 2003, 10:04 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
What they said - you're using the wrong stuff. 5 minute is junk, go with 30..
..a
Old Jul 26, 2003, 10:06 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
GOOP??
hoppy is offline Find More Posts by hoppy
Old Jul 27, 2003, 09:50 AM
M.PROTZEK's Avatar
Reidsville, N.C.
Joined Jan 2001
Thanks everyone, I am going to pickup 30 min epoxy today.
Old Jul 27, 2003, 02:17 PM
Fredrik W's Avatar
Stockholm, Sweden
Joined Jul 2002
Like Brian said - very important that you rough up the glass just before you use that epoxy! Or else the epoxy molecules will have problem to attach to hardened molecules.
And yes, 30 min epoxy is much better than 5 min.
// Fredrik Wergeland
Sweden
www.flyingmodels.org
The Great Electric Motor Test
Fredrik W is offline Find More Posts by Fredrik W
Discussion JB Weld for motor mount?s crocket High Performance 8 May 18, 2006 11:32 AM
Looking for motor mount for the K278 fly_boy99 Power Systems 0 Oct 17, 2005 08:01 PM
One or two set screws for motor mount? Jim13704 Power Systems 0 Jul 21, 2004 01:51 PM
Looking for motor mount for a Kontronik 500 with 5:2.1 geardrive Michael Heer Scale Kit/Scratch Built 6 Mar 31, 2004 09:13 AM
I.F.O. mark 3 pictures needed for assembly of motor mount and battery mount spy0o7 Electric Plane Talk 2 Jun 19, 2001 03:48 AM
