Old Jul 07, 2014, 09:18 AM
United Kingdom
Joined Jan 2013
Help!
Trouble getting F18 to fly - help needed
I bought a Skyangel Nano F18 35mm. I just can't seem to get it to fly.
TAKE 1
Completely stock PNF. Ran it on 2S Nano techs. It would sort of fly/glide for about 3 car lengths then come down fairly gentle slightly nose first. Tried full power, 80% power. Moved the battery back and forth. But it just seemed like it didn't have enough power to fly.
TAKE 2
Upgraded to a 12amp Turnighy Plush and some 3S batteries. I checked out the CG and it's between 33-36mm. If I throw the plane with no power on it glides fairly level for a car length or so. A bit like a paper airplane would and comes down slightl nose first.
With power on when you throw it, it just flips and twirls. Completely unpredictable and will land in a heap in any orientation only 3-10 feet away.
Again I've tried moving the battery forwards and backwards to try and eliminate a CG issue. But no matter what I did it appeared to have little or no affect.
Really looking for some help as I'm kind of out of ideas if what to look at now.
ChickenDrumstick is offline Find More Posts by ChickenDrumstick
Old Jul 07, 2014, 03:02 PM
United States, TX, Dallas
Joined Jan 2011
Tiny EDF
Sounds like you have found the proper CG location because it glides well power-off.
Use the location that begets the longest glide. Our jets are inherently unstable under power because the thrust exit is way behind the CG, pushing it. At low airspeeds this instability is more pronounced. You've gotta "be on it" during the launch sequence, using the ailerons to level the wings- the plane wants to roll due to the instant torque generated by the electric motor.
Hold the plane by the tip of the nose and hang it vertically, nose up. Apply full throttle. If the thrust equals the weight of the plane, it will hang there in midair. If it does, you have enough power to fly with authority.
Fanflyer is offline Find More Posts by Fanflyer
Old Jul 07, 2014, 03:48 PM
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
What C rating are your packs?
dedStik is offline Find More Posts by dedStik
Latest blog entry: More Confessions of a Smoker
Old Jul 07, 2014, 04:13 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Did you think about starting at 50%-60% --
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jul 07, 2014, 05:41 PM
United Kingdom
Joined Jan 2013
I've got a couple of 500mah which are 35C I think and a 370mah which is 25-45C. They where the best 3S batteries Hobbyking UK Warehouse had in stock in this size range.
Old Jul 07, 2014, 05:43 PM
United Kingdom
Joined Jan 2013
Yeah I tried quite a few different throttle settings from about 1/4 throttle, half and so on. Going to give it another try tomorrow night hopefully.
Old Jul 07, 2014, 10:51 PM
United States, FL, North Port
Joined Mar 2004
Try letting someone else throw it while you fly
invertmast is offline Find More Posts by invertmast
Old Jul 08, 2014, 12:47 PM
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
that whole statement is complete nonesense.
skyhawk is offline Find More Posts by skyhawk
Old Jul 08, 2014, 04:08 PM
airboss/oc's Avatar
United States, CA, El Mirage
Joined May 2007
made sense to me , what parts do find "nonsense"
airboss/oc is offline Find More Posts by airboss/oc
Old Jul 09, 2014, 01:51 AM View Post
blasiteomba
A moderator felt this post violated the following rule: Trolling (Obnoxious behavior). Show it to me anyway.
Old Jul 10, 2014, 06:33 PM
Double E's Avatar
Atlanta, GA
Joined Mar 2009
Try to ROG it from the grass, that way you are less likely to damage the aircraft from a bad throw or setup. If you can get it to ROG then it should be good enough to fly and trim out. I ROG my Skyangel F18 and F35 and they seem to do fine.
Double E is offline Find More Posts by Double E
Old Jul 10, 2014, 11:46 PM
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Not necessarily. Hanging a jet vertically is a good indicator of how much static thrust it's developing. Since a hand launch starts at very low speed, the amount of static thrust is important.
With that said, a lot of static thrust is not a very good indicator of how fast the jet will go once it's flying.
One part that doesn't make sense to me is the torque statement since torque is usually a by-product of prop wash and EDFs have very little if any torque roll.
CD: Do you have someone that can help you with the hand launch? I recommend an overhand throw rather than side arm. It tends to reduce the wobbling on launch.
Daren
Daren is offline Find More Posts by Daren
Old Jul 12, 2014, 02:34 AM
James L
TANGOSIERRAROM's Avatar
Beck Row Mildenhall
Joined Mar 2009
It sounds a bit like a thrust line issue
TANGOSIERRAROM is offline Find More Posts by TANGOSIERRAROM
Old Jul 14, 2014, 03:33 AM
United Kingdom
Joined Jan 2013
Had another go with this bird at the weekend. Before making the attempt I'd gone back and checked over the plane again. I moved some of the control horn links for more throw and checked as best I could the fan placement and thrust line (don't really have anything to work with, but there are some cutouts in the foam and it seems to be aligned well with them).
I did get it airborne this time after a few attempts, but it was only just. The flight didn't last long sadly there seemed to be almost no direction control. I managed to fly it out ahead of me and make a left turn, although it may have done it all itself. It refused to climb at anything more than a very gentle climb (maybe 15-20 degrees from the ground) and didn't really seem to want to respond at all to aileron inputs, e.g. full aileron did not make it roll and hardly made it bank.
In the end after making a wide sweeping left turn it banked over and came in nose first. It was also moving at one hell of a rate (fastest thing I've flown). So I don't know why it didn't have any real control. I accept part of it could be me, but when you are moving the sticks and the plane pretty much ignores them, I'm not sure what you are meant to do.
The good news is, some time with a hair dryer and some glue and it's back in a fairly straight order. So going to give it another go, although I might see about altering the throws again.
Old Jul 15, 2014, 07:17 AM
James L
Beck Row Mildenhall
Joined Mar 2009
Seems to be problematic. It has coupled aileron and elevators are you sure this all doing what it should be eg apply left stick right ailereron down
Discussion Help needed, noob in trouble. crslaytor Multirotor Talk 8 Jun 27, 2014 03:54 PM
Discussion New Phantom 2 owner needs help trouble shooting start up jettrc Multirotor Talk 0 Jan 25, 2014 01:01 AM
Discussion NEED HELP PLEASEEEE-Phantom Wont Fly One3esco Multirotor Talk 0 Oct 13, 2013 12:34 AM
Discussion Apprentice S15 e trouble shooting - newbie in need of help Dentalpiano Electric Plane Talk 3 Sep 22, 2013 11:05 PM
Need Help getting her to fly John Boren Foamies (Kits) 2 Jul 07, 2003 10:03 PM
