Old Mar 23, 2014, 04:49 PM
Joined Jun 2012
my first fpv setup-help
hello guys i need some advice from you i'm planing to do this setup
Skyzone FPV Goggles 5.8GHz Dual Diversity 32CH Receiver With Head-Tracker
Boscam FPV 5.8GHz 600mW 32CH A/V Transmitting (TX) Module TS832 RP-SMA
ImmersionRC 5.8GHz Circular Polarized SpiroNet Antenna V2 (SMA)
Fatshark FPV - Headset Battery 7.4V 1000mah w/Banana Charge Lead
Mobius Wide Angle B Lens ActionCam a 1080p HD Video Camera Set With Live Video Out
Hobbyking Bixler v1.1 EPO 1400mm
what do you think is it good setup do i miss something,will it works
many thanks
lukino37 is offline Find More Posts by lukino37
Old Mar 23, 2014, 05:06 PM
KK4NOP
Mike Freas's Avatar
United States, VA, Virginia Beach
Joined Aug 2005
many thanks
Consider using a board camera for FPV vice the Mobius.
Mike Freas is offline Find More Posts by Mike Freas
Latest blog entry: Pan/Tilt servo mods
Old Mar 23, 2014, 05:24 PM
Joined Jun 2012
is the mobius not good for a board camera then
Old Mar 23, 2014, 05:46 PM
FPV Proximity is FUN!
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
You might notice some lag or latency with the mobius. I prefer to use a separate camera dedicated for FPV. Also you might need a SMA-RP-SMA Adapter for your antennas.
-Ben
fOaMmaSh87 is offline Find More Posts by fOaMmaSh87
Old Mar 23, 2014, 06:33 PM
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
The Mobius is great, don't listen to the haters.
Teamsherman is online now Find More Posts by Teamsherman
Old Mar 23, 2014, 09:39 PM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
I meant nothing against the Mobius I'm ordering one soon anyway!
Old Mar 23, 2014, 10:13 PM
Member #1
Joined Aug 2011
That's cool, but in general there are a lot of guys bagging it out without even trying it for themselves and they are just going by what the haters are all saying!
I love it and honestly think it's better than any separate FPV camera I've ever used and that INCLUDES the Pixim SeaWolf WDR 690 TVL!!
Old Mar 23, 2014, 11:52 PM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Yes I have seen some of that happening on the Scale FPV forum ect..
Old Mar 23, 2014, 11:58 PM
Joined Oct 2011
Need a little help
I've been flying around 5years and want to fpv and got a 5.8setup off eBay 200ma transmitter and the 5808receiver with clover antennas holding the transmitter powered by a 500Mah3s and walk I can only get about 50 feet and the screen flickers and goes out I've tried different channels and nothing changes what can the problem be.
I really want to do the fpv thing but spending money to get no results is starting to suck any advice
sellers11535 is offline Find More Posts by sellers11535
Old Mar 24, 2014, 12:04 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Hey,
That happened to me when I first started. Get some FPV goggles or a FPV screen from RMRC or RV. Most common cheap screens blue screen. Could you post some pics of your set up?
-Ben
Old Mar 24, 2014, 01:00 AM
Joined Oct 2011
Don't get blue screen, just losing signal completely at 50_ 60 feet
It not mounted to plane or quad yet
Old Mar 24, 2014, 05:06 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Yep does your screen go black?
Old Mar 24, 2014, 05:34 AM
Member #1
Joined Aug 2011
Sounds like the Video receiver is on the wrong channel.
Test the channel that is one up and the one that is one down from the channel that only gives you 50 feet and I'd bet its actually one of them and not the one you are seeing the picture on.
I did that a few weeks ago, I changed the channel thinking it was the right one but once I flew about 50m away, my picture died very quickly and so I landed and chranged the Vrx channel up one and that was the right channel and I then proceeded to fly a few hundred metres away.
Old Mar 25, 2014, 09:05 AM
Joined Oct 2011
I'll give that a try
thanks
Old Mar 26, 2014, 08:02 AM
Australia, QLD, Gold Coast
Joined Apr 2011
I hate to say it but my money is on the fact that ebay stuff generally sux :-/
Not to say its all bad, but there is a LOT going on with your video and control link, and compromising in either one of these areas is just not worth it.
I made the classic noob mistake a few years ago with a crazily powerful awesome sounding ebay vid tx/rx and couldn't get it working more than 50 meters away, and that was by itself without even trying to use it with my rc link at the same time.
Without going into detail, there's a lot of work that goes into making good video link and rc link components like the stuff from rmrc I recommend and dragonlink uhf. They're the only ones I've tried to be honest but they have worked 27,000 times better than any cheap ones I tried.
With the time I spent trying to make the cheap stuff work I could've saved up enough to buy a more expensive tried and tested setup a few times over lol
davedolby is offline Find More Posts by davedolby
Discussion Help me pick my first FPV setup please! NixANerd2 FPV Equipment 29 Apr 23, 2014 09:00 AM
Discussion New to FPV, here is my first setup. Kg4ceo FPV Talk 5 Mar 02, 2014 06:20 PM
Discussion Help buying first fpv setup shniggysaurus FPV Equipment 8 Dec 28, 2013 08:51 PM
Wanted Please help me round out my FPV setup swshouse FPV Equipment (FS/W) 0 Oct 11, 2013 02:46 PM
Discussion My First FPV setup... help me out! justind123 FPV Talk 22 Dec 29, 2009 10:55 PM
