Old Jan 19, 2013, 09:54 PM
ryanbe15's Avatar
United States, MD, Bethesda
Joined Sep 2012
DLE 20cc questions
First time with a gas engine.
How much fuel does the 20cc gulp per minute. I'm thinking of going with an 8 oz tank.
How much battery will a 20cc engine ignition use for a 10 minute flight?
ryanbe15 is offline Find More Posts by ryanbe15
Old Jan 20, 2013, 05:30 AM
Kansas City
Joined Apr 2010
An 8 ounce tank would be fine. I mostly use 10 ounce tanks on my 20 cc engines but seldom fly over 10 minutes and never run out of fuel. I have tracked battery usage on ignitions and consistently come up with a 10 ma per minute draw. 10 minute flight would equal 100 ma used.
Best regards.
Lifer is offline Find More Posts by Lifer
Old Jan 20, 2013, 05:58 AM
USA, AR, Austin
Joined Jun 2009
One problem wiyh 8oz than is getting clunk line to flex enough ,Tygon is to stiff.
tower flyer is offline Find More Posts by tower flyer
Old Jan 20, 2013, 07:37 AM
ryanbe15's Avatar
Joined Sep 2012
Thanks. I wish these came in a 10oz or 12oz tank.
http://www.aero-works.net/store/detail.aspx?ID=488
Guess i could buy a 16oz tank and just not fill it all the way. What i'm trying to avoid is the massive CG change as fuel burns off.
In your Gas planes, where are you mounting the tank?
Old Jan 20, 2013, 10:19 PM
Zor
Ontario,Canada
Joined Feb 2007
Best regards.
Caution _ _ _
ma (miliamperes) is not a quantity of elctricity.
You cannot take the intensity 10 ma per minuite and claim 100 ma after 10 minutes. The 100 ma is a rate of flow, not a quantity.
I figure you mean that if 10 mAh (mili-Amp-hour) which is a quantity has been used in the first minute then 100 mAh would have been used after 10 minutes.
A quantity of electricity is a rate of flow over a time period.
Similar to if one gallon of water per minute come out of a pipe then after 10 minutes 10 gallons have come out.
The ma is a rate of flow.
The unit for a quantity of electricity is the "coulomb".
One coulomb of elctricity is the quantity that passes a point at a rate of 1,000 ma ( which is one ampere) for a duration of one second.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jan 21, 2013, 05:37 AM
Kansas City
Joined Apr 2010
I don't know what your point is, but my point was to share my experience with another modeler. I charted battery usage for about 2 years and came up with the 10ma per minute rate. If you have something to share, then share it. If you just want to argue with everybody, join Congress.
Old Jan 21, 2013, 08:46 AM
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
You may want to look at these clunkless tanks too?
http://www.jlproducts.net/ProductRotoFlow.html
I have not used mine yet but I like what I read.
P.S.
Join Congress. That's good!
scootrb4 is offline Find More Posts by scootrb4
Old Jan 21, 2013, 11:15 AM
Illegitimi non carborundum
grosbeak's Avatar
Joined Mar 2011
Use Viton instead - it's much more flexible and doesn't need to be replaced nearly as often.
grosbeak is offline Find More Posts by grosbeak
Old Jan 21, 2013, 04:28 PM
Zor
Ontario,Canada
Joined Feb 2007
I simply shared some of my knowledge of electricity with you.
You obviously do not appreciate that.
Zor
Old Jan 21, 2013, 04:44 PM
Zor
Ontario,Canada
Joined Feb 2007
P.S.
Looking at the link it is evident that someone did some thinking
Wishing you realize what you consider "good" if you are not yet a "congress person".
Zor
Old Jan 21, 2013, 11:47 PM
Joined Mar 2012
Zor
600mAh, there I share my math with you. Go forth a do good things.
Craig Downer is offline Find More Posts by Craig Downer
Old Jan 21, 2013, 11:52 PM
Joined Mar 2012
Zor
What happens when the plane is pointed up or down for extended periods?
Old Jan 21, 2013, 11:54 PM
Joined Mar 2012
Center the tank on the cg, you will barely notice any change in flight.
Old Jan 22, 2013, 09:35 AM
scootrb4's Avatar
Joined Nov 2011
It goes out of sight or it hits the earth
Seriously though. That's a good question, even if the pick up does slide forward it's rigid rear facing position would not allow pickup of some of the fuel in a vertical dive... I have one under the bench, not yet tested.
Comparatively, even a conventional clunk is not reaching the front of the tank so there should be no difference in fuel availability with regards to tank position.
Old Jan 22, 2013, 10:30 AM
Joined Mar 2012
I wonder if you can put a tube and clunk on the brass pivot pickup do hickey thing, maybe you have to shorten the brass a bit?
I have been running a 16oz tank with the dle20 and get over 20 minutes of flight, but I think the last 5 minutes sucks a bit of air.
Sold DLE 20cc Jakedizzle Aircraft - Fuel - Engines and Accessories (FS/W) 16 Feb 12, 2013 09:12 PM
Discussion DLE 20cc timing Mgblunt Fuel Plane Talk 30 Jan 22, 2013 02:15 PM
HPI RS4 3 evo for a DLE 20cc brockettman Non R/C Items (FS/W) 0 Jan 13, 2013 08:20 PM
Discussion EE60 goes DLE 20cc Gas guinnb 3D / Fun Fly Fuel Planes 12 Apr 24, 2012 08:31 PM
Discussion DLE 20cc VS DLE 30CC Performance/Weight mikes68charger Engines 6 Apr 21, 2011 11:23 AM
