Old Jun 19, 2012, 08:55 PM
Joined May 2011
Regulator between 2s LiPo Rx and 6.0V servo??
Hi folks, I want to run a Hitec 5646 waterproof servo and a 5086 as well on the same Rx at the same time - but I want to take advantage of the 5646's high voltage capability.
So the Rx will be powered directly by 2s LiPo, and the 5646 will have full power, but:
Can I run a regulator between the Rx and the 5086 on the power leads, leaving the signal wire direct? This way the 5086 sees only 6V as it was designed to do..
Please let me know if this will work!
- Mike
northernmike is offline Find More Posts by northernmike
Old Jun 21, 2012, 12:36 AM
Romania, Dolj, Craiova
Joined Sep 2007
Use LiFePo4 instead and regulator no more needed.
This is the real solution.
renatoa is online now Find More Posts by renatoa
Old Jun 21, 2012, 05:39 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
YES. Done often in heli setups where tail servo can only take 4.8v. Here's the one we've used before.
http://helidirect.com/align-51v-two-...tor-p-7099.hdx
You can see in the picture how the system is powered by 7.4 2s lipo but the one rudder/tail servo is powered by the step down regulator.
freechip is offline Find More Posts by freechip
Old Jun 21, 2012, 05:44 AM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Originally Posted by RENATOA View Post
Use LiFePo4 instead and regulator no more needed. This is the real solution.
Don't see how using a LifePo4 instead of the regulator will provide the 2 different voltages the O.P is looking for.
Old Jun 21, 2012, 06:23 AM
Joined Sep 2007
not two voltages, everything on 6.6V of 2s LiFePo4 pack.
Any servo rated for 5 NiMh works well at 6.6V.
Old Jun 21, 2012, 06:25 AM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Yes I know, but what about the other servo that works on 7.4V and he wants to use a 2s for it?
Thats what he's looking for from what I read.
Old Jun 21, 2012, 06:59 AM
Joined Sep 2007
He wants or he needs to be run at 7.4V ? Not enough torque at 6.6V ?
Old Jun 21, 2012, 07:13 AM
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
A regulated servo will work-
The ALIGN setup is specifically for cases where a low voltage for servo is needed
With the exception of helis where the gyro/servo combo is voltage critical - there really isn't any need for these setups -that I know of
The HV servos work quite well at 6.3 volts and most modern digitals also work well at this voltage - That is why the Life cells were mentioned
I use A123 for rx packs but for years some JR guys have used 2 cell LiPo packs directly -no regs- but it is possible to overload em!
Tiny servos such as used with the 6400 series Spektrum Bind n Fly rx- use 3.5 v
If at all possible -just don't mix voltages or use regs when other choices are available. Just asking for trouble
richard hanson is offline Find More Posts by richard hanson
Old Jun 21, 2012, 08:14 AM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
LOL that I don't know, I was just going by what he posted. I am sure by now he's got what he's looking for so no need for me to stick around here.
Old Jun 21, 2012, 08:43 AM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Torque and/or speed. That's what I assume. The specs on the servo show distinctly higher speed and torque at 7.4.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jun 21, 2012, 05:32 PM
Joined May 2011
THANK YOU GUYS!
Yes, I want to run full voltage to the 5646 for max speed and power to pull in a large set of sails.
The top skipper at our pond is running a 7940TH on his sails and a 7235 for rudder, WAY out of my budget... though probably IP67 as my set-up.
I intend to use some very light 350mAh 65C cells so power via voltage is a huge plus, less current / motion saves me lots of weight.
Thank you thank you! Now I can start soldering!
Sold JR 9503 TX Battery, Charger and 6.0v 2500mah RX battery NEW!! HD Hucker Aircraft - General - Radio Equipment (FS/W) 3 May 31, 2012 11:21 PM
For Sale Hobbico HydriMax NiMH 5C 6.0V 4200mAh RX Batteries 5jays Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 21, 2012 12:18 AM
Wanted 6.0v rx pack mikeochs Aircraft - General - Radio Equipment (FS/W) 0 Sep 05, 2011 03:45 PM
Help! Upgrade NiCad Rx bat to Lipo but 7.4v instead of 4.8 or 6.0v…how??? WBFAir Batteries and Chargers 2 Jun 01, 2009 09:08 AM
