Old Aug 11, 2003, 09:33 AM
Air-Gar's Avatar
Olympia, WA, USA
Joined May 2003
Short antennas for park flyers
I was told that there are very short antennas available to use in park flyers. Can anyone tell me what these are called, where to get them, and how well they work?
Air-Gar is offline Find More Posts by Air-Gar
Old Aug 11, 2003, 09:54 AM
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
Most of them are base loaded antennas and price and availablity depend on the particular model. They do reduce the range of the receiver. Some about 10% so more. There is an Ezone member you sells his model by mailorder and he has a post here in Parkflyers. It is called Jim's Antennas and you can find it by searching "antennas" He may well spot your post and respond. I have bought several of his for about $6.00 each (I think that's the amount) and they work fine. For parkflyers that you are going to keep well within the receivers stated range there is little harm in loosing the last 100 feet of the 1000 foot range when you always keep the plane within 500 feet of you.
Other people make their own versions and I have seen one version of them at R/C Country in Sacramento for $10.00 each. hope that helps.
PS I have one of Jim's antennas in use in my Funky Chicken!
Old Aug 11, 2003, 10:20 AM
Air-Gar's Avatar
Olympia, WA, USA
Joined May 2003
Michael,
Thanks very much. I'll check this out.
Old Aug 11, 2003, 11:49 AM
Motor Maniac
Orange County, CA
Joined Feb 2002
They work great in parkflyers. There are several different types, like the M-72U from Azarr (ecubedrc.com). He also makes a mid-loaded antenna like the one Mike Heer descibed, the Azarr lite. There are others as well, like the Deans base-loaded antenna. I have used the Azarr antennas with great success, and one of my friends has used the Deans base-loaded successfully. I have some Lightennas on order as well. Take your pick, I think they are all good products.
10Thumbs is offline Find More Posts by 10Thumbs
Old Aug 11, 2003, 11:59 AM
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
Are any of the micro antenna's available in 35Mhz? as i've had no
luck in finding any
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Aug 11, 2003, 12:16 PM
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Azarr makes his Antenna in 35mhz.: http://www.ecubedrc.com/antennas.htm
I carry Jim's Litenna (I've zero glitching in my GWS 4-Channel receivers since switching to them) for 5.50 each: www.ParkFlyerMotors.com
If you JUST need a Litenna, E-mail me, and we'll work out a more affordable shipping means than the standard 6.00.
WJ
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Aug 11, 2003, 12:23 PM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Cool - WJ I just sent you a message about the affordable shipping!
Old Aug 11, 2003, 01:14 PM
Senior Moment Member
SF Bay Area, CA
Joined Jul 2002
I've been wrapping my antennas around a regular drinking straw cut to around 5 inches (the straw, not the antenna) and have not had any problems so far flying at distances were I can still see the plane.
babblefish is offline Find More Posts by babblefish
Old Aug 11, 2003, 07:52 PM
Air-Gar's Avatar
Olympia, WA, USA
Joined May 2003
Thanks everyone for this valuable information.
I'll follow up on it right away.
Old Aug 11, 2003, 08:01 PM
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Another advantage to both my Lightenna and Azarr's is that you save a few grams over the old clunker antenna.
Happy|Harry, I've got a 35MHz version in beta testing now. Should be a few more weeks till there is a cheaper 35MHz short antenna out there.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
My Hangar is full
No Step's Avatar
Everett, Washington
Joined May 2003
The last reciever I bought, a Hitec Electron 6, they included a piece of plastic specifically for you to wrap the antenna on,.... if you wanted to. Warnings included not overlapping the wire. I'd heard of the HLG guys doing it but I never thought a mfgr would come out and sugggest it. It must work.
Blaze
No Step is offline Find More Posts by No Step
Latest blog entry: Please visit my Hangar,.....
Old Aug 11, 2003, 09:03 PM
29 rods from you in western WI
Karl Bē's Avatar
Joined Jan 2003
I haven't ever range tested my WS Deans whip to the point of signal loss. Actually, I haven't tested a regular wire that far either. I think my Hitec instructions recommend a successful range test at 50 yds with the tx antenna collapsed, and I get bored of walking at 150 yds. That's both factory wire and whip.
I'm using a Berg 5-DSP with it, and have calculated altitude (via aerial photo & trig) at 2300' and altimeter readings to 2000'. With a 4-5' span Slowstick or glider, losing sight happens well before losing range.
Karl
Karl Bē is offline Find More Posts by Karl Bē
Lithium Ion Laptop Batteries for Park Flyers John Boren Batteries and Chargers 64 Oct 22, 2008 08:17 PM
AMA for Park Flyers Wings Beginner Training Area (Aircraft-Electric) 59 Feb 24, 2005 11:19 PM
Which Computer radio for Park Flyers? Subysouth Radios 13 Jul 23, 2003 04:05 PM
Razor 300 vs Astro 010 for Park Flyers Gordon Johnson Parkflyers 8 May 31, 2003 01:39 AM
What Motor Upgrades for Park Flyers austinflyer Parkflyers 1 Dec 30, 2002 10:13 PM
