Old Apr 19, 2015, 02:29 PM
Ebola Monkey is offline
Find More Posts by Ebola Monkey
Ebola Monkey's Avatar
United States, IL, Homer Glen
Joined Mar 2015
ZMR250 Indoor hull project, problem
I'm building an indoor hull for my ZMR250.
It's 2 pieces, bottom with the prop openings, and top to attach to the quad, and stiffen it.
I flew without the top piece, bottom piece just pressure fit on with no problems.
When I finished the top, and glued them together I thought I was good to go. The problem now is that it spins counter clockwise, starting before it's even off the ground. I popped it up, and even with full right rudder it spins.
I checked the hull for prop damage, and there isn't any. So I know none of them were rubbing.
The gaps between the props and hull are about 3-6mm. I'm sure equal gaps would be ideal, but could this make it spin? The gaps should be the same as they were without the top.
Any ideas?
Ebola Monkey is offline Find More Posts by Ebola Monkey
Sold Joysway UH-1 (Project hull) Fidelity101 Boats (FS/W) 46 Oct 25, 2014 05:48 PM
Discussion Problem with turns and hull roll BenVK Scale Boats 44 Aug 02, 2014 11:44 AM
Discussion Boat hull frame projections redcraftmodels Dock Talk 1 Jan 12, 2014 12:59 PM
Looking For a Hull (Project boat helifan Boats (FS/W) 0 Jan 06, 2005 08:22 PM
