Old Nov 24, 2002, 09:24 AM
jlk is offline
jlk
Find More Posts by jlk
jlk
Lifetime Beginner
jlk's Avatar
Chicago & Tucson
Joined Sep 2001
VIP racer, CG and control throws
Hi,
I bought a VIP from someone and I don't have the instructions. Can anyone tell me the recommended CG range and the control throws? Also do they recomment aileron differential and how much.
Jordan
jlk is offline Find More Posts by jlk
Old Nov 24, 2002, 10:32 AM
ShredAir is offline
Find More Posts by ShredAir
slope'n somewhere in the Andes
ShredAir's Avatar
Peru, Puno
Joined Mar 2001
The designers recommend CG at exactly 33 mm behind leading edge.
Due to the single servo, aileron differential cannot be adjusted. For 1st flight, try aileron up 4mm left and right as measured at trailing edges. Elevator up/down 2 mm measured at trailing edge. Adjust to taste. Good luck!
Dieter Mahlein
http://shredair.com
ShredAir is offline Find More Posts by ShredAir
Old Nov 24, 2002, 01:57 PM
jlk is offline
jlk
jlk
Lifetime Beginner
jlk's Avatar
Chicago & Tucson
Joined Sep 2001
Thanks Dieter.
Jordan
Old Nov 26, 2002, 08:07 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
33mm?????? I have mine at 41mm.... flies great, not overly sensitive to elevator.. I'd be afraid of snapping out of turns w/ the cg at 33m
tic is offline Find More Posts by tic
Old Nov 26, 2002, 09:57 PM
ShredAir is offline
ShredAir's Avatar
Peru, Puno
Joined Mar 2001
Yes, I wondered about that when I looked at that wing. TLAR says 41 is about right. Today, I saw one fly at 33 mm. Time to finish my own and see for myself.
Dieter
Old Nov 26, 2002, 10:22 PM
Mitch G is offline
Find More Posts by Mitch G
Mitch G's Avatar
Naperville, IL USA
Joined Nov 2000
Re: VIP racer, CG and control throws
Originally posted by jlk
Hi,
Jordan
Jordan, you must let me (and Sal) know when you are going to be flying the VIP.
What are you putting in it for motor, etc.?
Mitch
Mitch G is offline Find More Posts by Mitch G
Discussion VIP CG and control throws ??? FREEFLY PR High Performance 10 Mar 18, 2006 10:00 AM
Positron CG and Control throws??? TGoodwin Sport Planes 3 Oct 28, 2001 09:13 AM
Positron CG and control throws? TGoodwin Parkflyers 1 Oct 27, 2001 02:40 PM
Triffik - CG and control throws?! Jensst High Performance 4 Oct 25, 2001 03:23 AM
Flea's CG and control throws WilliamSettle High Performance 6 Jul 27, 2001 11:07 PM
