Old May 01, 2015, 05:52 PM
agentorange90 is offline
Find More Posts by agentorange90
Joined Dec 2014
Scratch build electronics set..
I'm a total newb at building so need some help. Thanks already for the replies on earlier posts. I'm getting the Flite-Test 3 pack. Does anyone have any good youtube links on how to install the electronics?
Also, I've put together this list of hardware. Let me know if you guys have better suggestions or if I am leaving out any essential items. I'm thinking of going with a Spektrum since I have a Spektrum DX4E.
The OrangeRX from Hobbyking however is WAY cheaper so not totally against it; just do not want a bunch of compatibility hassles and do not want to get a new receiver. I'm going to eventually step up to a DX6; just not yet.
http://www.hobbyking.com/hobbyking/s...er_w_CPPM.html
Reciver:
http://www.amazon.com/Spektrum-AR400...trum+receivers
ESC:
http://www.hobbyking.com/hobbyking/s...457&aff=247441
Motor:
http://www.hobbyking.com/hobbyking/s...398&aff=247441
Servos:
http://www.hobbyking.com/hobbyking/s...928&aff=247441
Battery:
http://www.hobbyking.com/hobbyking/s...275&aff=247441
Thanks in advance.
agentorange90 is offline Find More Posts by agentorange90
Old May 01, 2015, 06:12 PM
mmattock is offline
Find More Posts by mmattock
Canada, AB
Joined Oct 2014
I would suggest the Plush 10A ESC instead, it is much lighter and will easily handle your motor.
http://www.hobbyking.com/hobbyking/s...ontroller.html
I would also use the HXT900 servos instead. I have had good luck with the Rhino batteries but I expect most of them are OK for this level of service.
Mark
mmattock is offline Find More Posts by mmattock
Old May 01, 2015, 08:53 PM
Atrocityx is offline
Find More Posts by Atrocityx
United States, NC, Holly Springs
Joined May 2013
Headsup hobby has helped me pick electronics.. Check them out they take a lot of headache away with there data on there motors section http://www.headsuphobby.com
Atrocityx is offline Find More Posts by Atrocityx
Old May 01, 2015, 10:15 PM
Joined Dec 2014
This looks like the receiver I need:
http://www.hobbyking.com/hobbyking/s...Sat_Port_.html
Looks like it binds ok w/ DX4E
http://www.rcgroups.com/forums/showthread.php?t=1575088
Old May 01, 2015, 10:25 PM
Joined Dec 2014
Thanks for the suggestion on Heads up Hobby - Hobbyking is severely out of stock on some of their receivers.
Looking at this receiver now:
http://www.headsuphobby.com/Power-Up...iver-G-656.htm
Old May 01, 2015, 10:48 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
I have about a dozen of them, great item and great price. And $2 shipping.
BHOFM is offline Find More Posts by BHOFM
Old May 02, 2015, 08:05 AM
Joined Dec 2014
I sent the guys at Head's Up an email asking if they can put together a power set for me. I'm in Atlanta and I'm just about done with Hobbytown. They have a few good employees but the bad ones have soured me from going in with this type of project. Then everyone on the forum is so helpful. Hobby King looks really cool, but geez they have a ton of stuff that is on back order.
Old May 02, 2015, 09:01 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
HK has less that good customer service as well. HU has the best. And they are close to you.
Old May 02, 2015, 09:19 AM
Joined Dec 2014
Here's the combo I'm looking at from Head's up. I'd rather just deal w/ one set of shipping costs. It's 37 bucks without shipping and a similar set from HobbyKing was 47 bucks.
1.receiver:
2.ESC
http://www.headsuphobby.com/HURC-10-...-ESC-G-640.htm
3.motor:
http://www.headsuphobby.com/Power-Up...otor-F-545.htm
4.prop
http://www.headsuphobby.com/GWS-6030...Prop-B-260.htm
5.servos
http://www.headsuphobby.com/Towerpro...ervo-B-510.htm
6.battery
http://www.headsuphobby.com/111v-350...tery-F-279.htm
Old May 02, 2015, 09:56 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
Go with an 8X6 GWS sf prop and a 2s 800 battery. That is about 70w and ten minutes flying time.
With a 10oz plane. I have a bunch of planes with this combo.
Old May 02, 2015, 11:00 AM
Joined May 2013
Headsup is my goto. Also I'd suggest buying some carbon fiber tube for any future planes they are cheaper than my lhs. And a must have in wings.. best of luck
And there shipping is jimmy johns fast
Old May 02, 2015, 11:08 AM
Joined May 2013
I would even go further to say that the hurc 300 size blue wonder clones are used in a lot of mid sized planes on the forum I would go with one of those same price and just slightly heavier. But the thrust is greater and will .I feel last a bit longer for other projects etc
As well as emax
http://www.headsuphobby.com/HURC-300...otor-H-650.htm I use the 1900 kv version for my xraycer pusher
And
http://www.headsuphobby.com/Emax-CF2...otor-H-440.htm
For.my 30 " ws 3d planes
The dby batteries are great as well price an longevity. I have been flying on mine for over a year now
There prop data is so helpful for newbies. Like me
I used to ignore all the excellent posts on what is best
And just went with my own common sense . Man was I wrong
Old May 05, 2015, 10:28 AM
Joined Dec 2014
So I ordered the HURC 300 'Blue Wonder' 1600kv Brushless Motor from Head's up with the ESC they recommended. I wasn't sure what battery to order so I went with a 2s 7.4V 500mah battery.
Is this going to work?
http://www.headsuphobby.com/74v-500m...tery-G-106.htm
I ordered all the other electronics so looking forward to doing my first scratch build. Head's up seems to be a very solid hobby outlet.
Old May 05, 2015, 11:12 AM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
That's my go-to motor for park flyer sized planes . With a 2S battery you'll get okay performance on the NutBall and Flyer , but you'll probably want to use a 3S battery for the Delta .
For all three planes , resist the temptation to add a lot of reinforcements ( tape , rods , dowels , etc. ) . They will ALL fly better ( and slower ) if you keep them lightweight , and be less likely to crash BECAUSE they fly better .
HeadsUp RC is great , I use them often !
balsa or carbon is online now Find More Posts by balsa or carbon
Old May 05, 2015, 04:04 PM
Joined Dec 2014
Thanks Balsa - yah, your the 2nd or 3rd guy who has good things to say about that motor. I took a stab but I figured the 2s 500 mah battery would work. I'm pretty stoked about building. I had been looking at buying a Carbon Cub or a T-28 as a step up but the more I flew my micro planes, the more I realized that I would need to learn the process of repairing so I figured I would go with a basic build like the nutball and pick and choose my own components. It's pretty cool because all the parts were less than 50 bucks. I'll post some more once I get the kits - I'm sure I'll need help.
Once I get the basics of building down want to build something like a 4 channel high wing trainer like a Sport Cub or Cessna.
Discussion mini vapor salvaging the electronics for a scratch build? pricelessppp Scratchbuilt Indoor and Micro Models 4 May 05, 2014 04:48 AM
Discussion First 3D scratch build. Need recommendation on electronics justin144 3D Flying 1 Mar 23, 2014 07:11 PM
Help! Have all electronics to build 30mm scratch build, which one? RcAirplaneNoob Scratchbuilt EDFs 1 Nov 15, 2013 08:58 AM
Discussion From Scratch Build, looking for electronics help k2spy04 Multirotor Electronics 1 Jan 04, 2013 09:14 AM
