Old Mar 07, 2014, 03:37 AM
Martin Turner is offline
Find More Posts by Martin Turner
Joined Feb 2013
Dual 90mm Fans
Hi Guys
Anyone know of where i could get dual 90mm Fans with 4KG of thrust each to total 8KG. One unit must run in the opposite direction (Counter rotation).
I want to run the set-up on 6S per side.
I am looking into building one of these amazing looking Rafales..
http://www.therccustomjets.cz/userFiles/img_1148.jpg
Cheers for any tips...
Martin
Martin Turner is offline Find More Posts by Martin Turner
Old Mar 07, 2014, 07:54 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Might be tough finding counter-rotating fans. But I wouldn't let that stop me. After building nine twin EDF's, I can not think of a single instance where asymmetric thrust was an issue.
No asymmetry issues were noted on three A10's, two F89's and four Twin Biz Jets.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Mar 07, 2014, 07:59 AM
Joined Feb 2013
Wow. Really so on all your dual EDF models, you noted no problems with both Fans rotating in the same direction ?...
Old Mar 07, 2014, 08:09 AM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Never was an issue with my ME262 or Windrider 737(built for a friend).
CR fans may be helpful if you are planning a model capable of hovering.
4stripes is online now Find More Posts by 4stripes
Old Mar 07, 2014, 09:17 AM
tom bacsanyi is online now
Find More Posts by tom bacsanyi
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
On propeller planes there is rotation in the prop wash and resulting torque applied to the airframe. The stators in a typical edf remove the rotation. No rotation, no torque.
tom bacsanyi is online now Find More Posts by tom bacsanyi
Old Mar 07, 2014, 09:32 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
I thought I had seen that kit before--
http://www.rcgroups.com/forums/showthread.php?t=1727001
pekos's has some fine designs, for sure.
I don't think 6s will cut it.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Mar 07, 2014, 03:45 PM
DocViper0071 is offline
Find More Posts by DocViper0071
"Viper has the lead"
DocViper0071's Avatar
United States, CA, Chula Vista
Joined Jan 2013
They are correct, no issues with same rotation twin fan setup. However, Hobby King sells them in their international warehouse:
http://www.hobbyking.com/hobbyking/s...Rotation_.html
You may find it domestically, but this may be suited for your requirements.
DocViper0071 is offline Find More Posts by DocViper0071
Old Mar 07, 2014, 04:24 PM
Joined Dec 2008
Right in the first post of his build thread, he says this
I plan for this plane 2x 90mm EDF from VASA and 12s Lipoly. Weight 7500gr. and thrust together 8500-9000 gr.
This one big plane. L= 75" ( 1/8th scale) So wingspan should be around 53" .
His estimated AUW is 17.6 lb. 8500-9000 gr of thrust is approx 18-20 lbs..
He is also running his VASA fans on 12s--ea. No running 6S per side here I'm afraid
Old Mar 08, 2014, 01:58 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by Martin Turner View Post
... Anyone know of where i could get dual 90mm Fans with 4KG of thrust each to total 8KG. One unit must run in the opposite direction (Counter rotation).... Martin
Hi Martin I've been flying two Rafales with twin 90's for several years now ... no issues whatsoever with two fans spinning the same way You can see several video of my Rafales on youtube under Aeronaut Rafale.
Seems like a nice project, when set up right the Rafale is a sweet flier, good luck with it !
Herb is offline Find More Posts by Herb
Old Mar 09, 2014, 12:18 AM
FrankW is offline
Find More Posts by FrankW
Danger! Danger!
FrankW's Avatar
Portland Intl, Oregon, United States
Joined Dec 2002
Counter rotating edfs sounds like a gimmick to me. Heck, I don't even use counter rotating set ups on my twin prop jobs. You'll be fine with two EDFs going the same direction, but you won't be so fine with only 6s on each fan with that large of a plane.
-Frank
FrankW is offline Find More Posts by FrankW
Old Mar 09, 2014, 12:41 AM
Joined Feb 2013
Thanks for your replies. Very Useful.
So from what I heard, that twin 90mm Rafale is being converted to run on a single 120mm fan, as there was problems with the dual set-up. I am guessing that weight vs power was the problem.
I don't think the Peko chap is ready to ship any of his kits yet.
So I am looking for a Jet Kit - I want to build something!
Anyone know of proven plans and ideally a short wood kit for a large 120mm Fan EDF Jet ?. Not confident enough to scratch build a big jet.
PS. Great looking Model Herb -
What power set-up?
What size ?
Old Mar 09, 2014, 12:34 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... So from what I heard, that twin 90mm Rafale is being converted to run on a single 120mm fan, as there was problems with the dual set-up. I am guessing that weight vs power was the problem. ...
Hi Martin, If you do the math correctly the Twin 90mm fan setup will fly just as well (if not better) than the single 120mm.
And cost-wise there will be no difference, in fact the Twin 90mm can be cheaper and just as efficient.
The main reason is largely the avaliability of relatively inexpensive yet very reliable ESCs (eg HW or YEP) and 90mm fan inrunner 36-39mm motors (Het, Neu, Tenshock, Leopard etc).
... Great looking Model Herb - What power set-up? What size ?
The two Rafales pictured above are both all-molded twin 90mm Aeronaut kits:
http://www.rcgroups.com/forums/showt...=343257&pp=100
http://www.rcgroups.com/forums/showt...=154235&pp=100
http://www.rcgroups.com/forums/showt...=915522&pp=100
The Rafale can still be bought for ex. here : http://shop.wemotec.com/index.php?k=18&lang=eng
Old Mar 10, 2014, 06:50 PM
Rich Uravitch is offline
Find More Posts by Rich Uravitch
Rich Uravitch's Avatar
Florida
Joined Sep 2001
S-3B Viking, twin 90mm HET, 6S per side. 82" span,17 #.
Rich Uravitch is offline Find More Posts by Rich Uravitch
Old Mar 11, 2014, 04:48 AM
BlazerB52 is offline
Find More Posts by BlazerB52
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
Love the viking, great job.
BlazerB52 is offline Find More Posts by BlazerB52
Old Mar 11, 2014, 09:53 AM
Arngeir Blakseth is online now
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
YES!
Ziroli F9F Panther, lots of people have successfully built and flown this design. It's designed for a Dynamax fan so 120-127 fans will fit easily, the plane will fly fine on a 12S 5000W setup. Plans, short kits, retracts and canopy and whatever else you need is readily available.
Arngeir Blakseth is online now Find More Posts by Arngeir Blakseth
Sold Scheubler 90mm fan and New Neumotor 1515y 1.5 1moparman1 Aircraft - Electric - Jets (FS/W) 0 Sep 28, 2013 06:37 PM
Wanted wanted 90mm Wemo fan josephcharles Aircraft - Electric - Jets (FS/W) 2 Sep 28, 2013 08:00 AM
Sold ARC 36-75-1 w/Wemo 90mm fan hole digger Aircraft - Electric - Jets (FS/W) 0 Sep 21, 2013 04:31 PM
Sold ChangeSun 90mm 12B 8mm Fan Unit NEW IntheTubeDeep Aircraft - Electric - Jets (FS/W) 1 Sep 20, 2013 04:28 PM
For Sale ChangeSun 90mm 12B 8mm Fan Unit NEW IntheTubeDeep Aircraft - Electric - Airplanes (FS/W) 0 Sep 19, 2013 10:42 AM
