Old Aug 25, 2013, 02:08 AM
micromantis is offline
Find More Posts by micromantis
No mods no glory!
micromantis's Avatar
United States, CA, Redwood City
Joined Nov 2010
UMX Habu DF Mod thread
This has been an awesome little jet and from the looks of it becoming a favorite among many.
Initial mods:
I had to add a little color to my canopy so I went with Tamiya TS-19 Metallic Blue.
The elevator needed 1mm carbon rod reinforcement just like the UMX Mig and 1.5mm stab through the rudder.
The main wing just need a 1.5mm carbon rod leading edge for protection.
CG has been marked at 40mm for me, it seems everyone has been setting theirs between 40-42mm, 37mm just was not cutting it.
Looking forward to some 3S UMX Habu's!
micromantis is offline Find More Posts by micromantis
Old Aug 25, 2013, 09:49 AM
waytooslow is online now
Find More Posts by waytooslow
Crash 'em if you got 'em
waytooslow's Avatar
United States, TX, Euless
Joined May 2013
sweet - on horizontal stab - did you recess the CF rod? threading CF through rudder, whats you technique? the last shot -- looks like rod in trailing edge - also recessed? Like the added blue as well.
waytooslow is online now Find More Posts by waytooslow
Latest blog entry: Top Flite P40 .60 is no more
Old Aug 26, 2013, 08:09 PM
walter3rd is online now
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
my cosmetic mods. anti-glare strip for pilot, aluminum jet exhaust, intake strip and military garb. much better looking IMHO. just the beginning too im sure. walt
walter3rd is online now Find More Posts by walter3rd
Old Aug 26, 2013, 09:55 PM
waytooslow's Avatar
Joined May 2013
my bad on leading edge -- must have been the shadow that threw me off.
so how are you slotting for the CF?
Old Aug 26, 2013, 10:53 PM
No mods no glory!
Joined Nov 2010
No recessing for the CF rods just held them in place very carefully CA'ed the both ends of the CF rod and added clear thin packing tape over them. You could however recess them very carefully on the elevator but no need. You could slot the leading edge of the wings and put the CF rod in there with a sharp #11 blade and put packing tape over that or CA it in or both.
Old Aug 31, 2013, 04:40 PM
walter3rd's Avatar
Joined Aug 2012
afterburner!
Old Sep 05, 2013, 08:53 PM
jahel is offline
Find More Posts by jahel
United States, FL, Clearwater
Joined Jun 2011
I makes some mods today on my habu, I slide it and put out the edf unit and receiver.
Mods:
Aeo 30mm 8 blades with 4 blades off
Spin motor 14000kv
Castle esc
28mm BIM edf unit
jahel is offline Find More Posts by jahel
Old Sep 05, 2013, 11:23 PM
waytooslow's Avatar
Joined May 2013
more details as you finish up!!!!
Old Sep 06, 2013, 06:04 AM
jahel is offline
Joined Jun 2011
of course!
Old Sep 06, 2013, 10:10 PM
jahel is offline
Joined Jun 2011
I waiting the BIM 28mm shroud....but I decide make few flights before with a 25mm unit...
Old Sep 06, 2013, 11:50 PM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Need for speed!
Ksqm
ksqm is online now Find More Posts by ksqm
Old Sep 07, 2013, 04:56 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Where did you purchase that motor – link please?
Also will that motor work with stock fan and ESC?
RC Man is offline Find More Posts by RC Man
Old Sep 07, 2013, 06:52 AM
jahel is offline
Joined Jun 2011
The motor a xtreme spin motor
http://www.amazon.com/gp/aw/d/B00CXZ...=A62A5QITNPU7J
The edf unit with Boredom:
http://www.rcgroups.com/forums/showthread.php?t=1731372
Here the rotor this need to trim a little:
http://www.hobbyking.com/hobbyking/s...GWS_EDF30.html
Old Oct 12, 2013, 09:38 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Guys, I did some mod's to mine for 3s and flew it this morning, as you might expect performance is significantly better than on 2s. I was disappointed in how slow it was out-of-the-box, it's performance on 3s is much more like what I initially expected. Here is a text I sent a buddy describing the mod's I made to it:
Conversion is done, it was pretty easy. I'll describe it while it's still fresh in my mind:
- The canopy is glued on, pry around the edges with your fingernails and it pops loose. There's an existing cooling hole in the foam at the front of the canopy, I opened it up some more with an Exacto. I also cut some additional exit holes in the back of the canopy (there are two small ones). I then pulled the batt lead up through the top to get it out of the way.
- Next I cut the foam out of the back of the batt bay all the way to the brick being really careful not to cut the servo wires (I moved them back and forth as much as I could while I worked). I basically extended the batt bay rearward so I could get the batt as far back as possible. The CG is still 1/4" forward of the RCG suggested mark, but I'm going to fly it that way and see how it goes. I cut a slot through the foam just behind the batt bay for some additional cooling directly over the brick, so it'll have air flowing from the top and bottom of the plane.
- Once that was done I used strips of clear packing tape to reattach the canopy.
- Then I soldered a new JST connector on. I remember you asking about soldering over foam, what I do is take a piece of foil and poke a hole in it, then run the leads through that and lay the foil over the plane. The foil dissipates the heat, even if you drop solder on it the foam will be fine. The leads you're soldering are short, so to keep the shrink from "pre-shrinking" while I'm soldering I wrap a wet paper towel around them and put an alligator clip on it to hold it in place. Then you can heat the solder up as much as you want and the shrink is unaffected.
That's really about it. I ran it up on the Whattmeter and it showed 5 amps, but I get some losses through the Whattmeter so it's drawing more than that.
I'm flying it on 3s 250 TP's. Flight times are short- pack was dropping fast when my 3 min timer went off so I've adjusted it to 2:45. That was flying at or near WOT the whole flight. The slightly forward CG doesn't really matter on 3s. On 2s it'll barely loop with a rearward CG, but on 3s it powers through loops just fine even with a forward CG. It'll go vertical a while, but certainly not unlimited. Pack came down warm, so I've since cut some cooling slots in the foam on either side of the pack. Packs are charging now and then I'm going to take it out again to see if it helps.
I fly on a grass field without the landing gear. Hand launching seems just as easy even with the heavier pack. Landings are also a breeze, power off it practically lands itself.
I've read at least one report of premature ESC shutdown (probably over-heating), that's why I made sure to add the extra cooling. I had no issues and like I said I flew it at or near WOT the whole time, and I did extended WOT runs several times. Hopefully it'll continue to stand up to this long-term, time will tell.
Tres Wright is offline Find More Posts by Tres Wright
Old Oct 14, 2013, 08:17 AM
Forney, TX
Joined Mar 2002
Flew 6 flights over the weekend on the 3s setup. The only issue I've had is sometimes it goes through the initialization and gives all the tones including the final one, but afterwards the plane is dead- no servo movement, no motor. One time I had to unplug it and plug it back in half a dozen times before it finally worked. I'm guessing the higher voltage of the 3s pack is confusing the brick sometimes. Anyway, once it fires up I've had no problems in-flight.
The little jet is an amazing sport flyer on 3s. It'll do knife edge the length of the field, big inside loops, big outside loops from inverted, decent vertical, victory rolls, big split esses and immelmans, 4 point rolls, etc. I'm putting about 200 mah back into the packs after a 2:45 flight. Sure wish it flew longer, 4 minutes would be perfect. I think a bigger pack would start to weigh it down though.
Discussion Official Eflite UMX Habu DF Owners Thread NitroCharged Micro EDF Jets and Power Systems 2138 Feb 12, 2016 03:26 PM
Discussion Official Eflite UMX Mig 15 DF Owners Thread NitroCharged Micro EDF Jets and Power Systems 5608 Jan 10, 2016 02:28 AM
News E-flite® UMX™ Habu DF BNF Basic awagar Electric Ducted Fan Jet Talk 27 Jan 06, 2016 07:41 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
