Old Jan 12, 2013, 02:23 AM
hookpilot is offline
Find More Posts by hookpilot
hookpilot's Avatar
Metric Steam Throttle Valve and 5/32" Tubing
I've found a source for a steam regulator valve (RC steam throttle valve) from France. My question: It's metric and comes in a 3.5mm and 4.0mm size. I'm using 5/32" diameter copper steam lines. Will this 4mm valve work?
Snagboat Mike
hookpilot is offline Find More Posts by hookpilot
Old Jan 13, 2013, 06:33 PM
zorrow is offline
Find More Posts by zorrow
zorrow's Avatar
United States, WA, Everett
Joined Apr 2004
conversion
5/32" =0.15625"
0.15625 / .0394 = 3.965mm
use the 4mm
zorrow is offline Find More Posts by zorrow
Old Jan 13, 2013, 09:39 PM
Oian is offline
Find More Posts by Oian
USA, CA, Selma
Joined Sep 2004
Here's a link to a site with a free, downloadable, conversion program which will convert almost anything to anything. I've used mine quite a lot and it works great. As example on the "Distance"tab (length) there are 17 different length units, all the way from nanometer to parsec. So in the case above just select inch for the input box and millimeter for the output box, then type in the inch box the decimal equivalent of 15/32, (.15625), the program doesn't do fractions, and the equivalent in milimeters 3.96875 will appear in the output box. There are 22 tabs of things to convert! Check out the site and see what it will do.
http://joshmadison.com/convert-for-windows/
John
Oian is offline Find More Posts by Oian
Discussion Steam Pipe vs. Steam tubing hookpilot Steam Boats 26 Nov 19, 2012 09:40 AM
Discussion 5/32" tube strong enough for roll cage? The Touch Australia 10 Aug 18, 2008 08:17 AM
Wanted dubro 5/32 tubing bender dmiller746 Aircraft - General - Miscellaneous (FS/W) 0 Feb 08, 2007 09:58 PM
