Old Dec 10, 2010, 12:20 PM
ZEROSKIN76 is offline
Find More Posts by ZEROSKIN76
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
mirage 2005-5 wattage watt age?
i just recieved mine from fellow forum member
i have esc and radio gear with mixing
i waas wondering if a esy 1000mah 12c 2s cell would do the trick i want it kinda slow i have a nimh cell that would be to spec but want longer flights with less speed
ZEROSKIN76 is offline Find More Posts by ZEROSKIN76
Old Dec 10, 2010, 02:24 PM
sgonzo is online now
Find More Posts by sgonzo
littleton, colorado
Joined Jan 2003
I think it depends on the motor and prop combo you are running. A high KV motor and a small prop won't get enough amps from a 2 cell to run well, and hand launching will be a real bear to get up to speed quickly enough.
You may get away with a lower Kv motor (more torque), and bigger prop with a 2 cell battery as the Mirage is a delta wing, and delta wings are known to have much better low speed qualities than an F16. It will probably be marginal though, and take-offs will be sluggish. Save up the money and buy a 3 cell, it will be worth it- you can fly slow or fast using your throttle! Have fun and good luck.
sgonzo is online now Find More Posts by sgonzo
Old Dec 11, 2010, 05:14 PM
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
how many oz of static thrust are needed to fly this model
For Sale *NIB* Wattage Mirage 2000-5 (very rare) splitpilot Aircraft - Electric - Jets (FS/W) 4 Dec 10, 2010 11:59 AM
FS cheap Watt age Mirage not nib RacerPaul Aircraft - Electric - Airplanes (FS/W) 4 Jun 04, 2003 05:53 PM
WTB: Watt-age Mirage Parts ArcherAce Aircraft - Electric - Airplanes (FS/W) 2 Apr 29, 2003 01:24 PM
WTB: Watt-age Mirage genovia Aircraft - Electric - Airplanes (FS/W) 14 Nov 11, 2002 10:39 AM
WTB: Watt-age Mirage genovia Aircraft - Electric - Airplanes (FS/W) 0 Nov 03, 2002 05:35 PM
