Old Jun 21, 2006, 12:03 PM
Medve's Avatar
Joined Apr 2004
source for tri blade prop.
we're thinking of using a tri blade prop on our AP/UAV for the added torque, quieter, and also the smaller diameter. This is in a pusher config. Can any of you recomend a good source for tri blade props? My LHS's don't carry them, and I want to get some decent quality ones. If you all have tips on using a tri blade prop. please feel free to toss them my way. The plane will be about 30 inch span, weigh around 3-4lbs. and have a little over 900 sq. inches wing area.
I'll have to figure out the right motor/prop. combos.
Thanks and have a good one.
Medve is offline Find More Posts by Medve
Old Jun 21, 2006, 05:02 PM
winnipeg
Joined Jan 2004
Here is a link for a 3-blade hub If you are going electric.
http://www.hobby-lobby.com/freudaccy.htm
builder is offline Find More Posts by builder
Old Jun 21, 2006, 05:22 PM
Professor of Wood
kd7ost's Avatar
Nampa. Idaho
Joined Nov 2004
Electric or Wet Fuel? What size prop? There aren't many pushers available as three bladed props but I get mine from Tower Hobbies. A reversible motor(brushless electric) gives you more options.
Dan
kd7ost is offline Find More Posts by kd7ost
Old Jun 21, 2006, 09:36 PM
Medve's Avatar
Joined Apr 2004
sorry, I should have mentioned it was electric. Same one I'm working on 30" wing with tube fuse. Just put this in different thread in case the 2-3 bladed issue was needed by someone later, they wouldn't have to dig through some other post. I'll check those links. Thanks.
Old Jun 21, 2006, 11:24 PM
Professor of Wood
kd7ost's Avatar
Nampa. Idaho
Joined Nov 2004
It might be hard to find three bladed props optimized for electric motors. It's also more efficient to run a longer two bladed prop than a shorter three bladed one. I do use my three bladed pusher to get more ground clearance. I keep breaking the two bladed wooden ones.
Dan
Spinner for a 4 blade Prop Fundy Sport Planes 4 Apr 13, 2005 10:33 AM
Help! 1 1/2" Spinner for 3-blade prop? GroundBound Scale Fuel Planes 4 Jan 26, 2005 08:33 PM
Source for replacement Spitfire prop? lrsudog Parkflyers 0 Oct 02, 2003 01:15 PM
4-blade prop for GWS P-51? snailster Parkflyers 3 Feb 07, 2003 12:21 AM
Looking for low pitched 3 or 4 blade prop roguewolf Scale Kit/Scratch Built 16 Jan 24, 2003 11:13 AM
