Old Oct 29, 2011, 04:23 PM
Joined Dec 2008
Mig 21 intake
Hi folks . I plan on modifying my HET mig21 intake and making a duct for it.After cutting the battery Canoe out of the way along withthe nose cone . I plan on making an intake duct (with a smaller nose spike )out of blue foam , then glassing over it and melting out the foam with gas .The battery will then sit on top of the glass intake duct .What I would like to know is , Do I need the intake ring in front of the fan , even if I run a duct ?If so would I make the end of the duct that comes up against the 6904 fan ,big enough to slip over the intake ring ? Or do I skip the ring altogether ?
pencon is online now Find More Posts by pencon
Old Oct 29, 2011, 07:28 PM
Da' Cajun
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Skip the ring, run the duct right up to the fan and slip it over the housing.
I'd love to see some pics before/during & after you get it done. I've got a set of MiG 21 plans and will scratch build one someday. The duct work is tricky on this one with the shock cone in the way.
Julian
Boogie_ is online now Find More Posts by Boogie_
Old Oct 29, 2011, 07:46 PM
Joined Dec 2008
Well Boogie I just ripped out the shock cone tray . So Now I'm committed .Time to build a proper 70mm duct for the old Mig and get this ball rollin...
Old Oct 29, 2011, 07:53 PM
Joined Dec 2008
What do you think of this idea - Make a 70mm duct and then squeeze it a little flat so that the sides meet the edge of the inside of the fuse which is about 95mm wide?The duct would then be more of an oval shape like on an f16 while still leaving enough room above for battery and esc ? The Duct would sit on the bottom of the Fuse and have to curve up to meet the fan which is centered in a bulkhead .This setup would have to flow better than the old one which was a plugged up nightmare .
Old Oct 29, 2011, 09:51 PM
Da' Cajun
Boogie_'s Avatar
Joined Jun 2009
That would work fine. I took a similar approach on my F-84F build, works great.
Try this:
Make a paper tube 100% FSA, 2.45" dia (62.23mm), and fit it down in the fuse and see how much room you've got. That will give you an idea how much room you'll need to make to get the batts in there.
Make the intake a bell shaped opening and have the shock cone in a teardrop shape held in place by thin ply vanes. The duct will taper down to the 2.45" dia behind the shock cone and then flare out again to slip over the fan housing.
You may have already thought of this (or something even better). I've been mulling this over for sometime and would like to see how some one else figures this one out.
Old Oct 30, 2011, 01:34 AM
Joined Dec 2008
Is that the FSA of the 6904 fan ?
Old Oct 30, 2011, 02:01 AM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
as long as you area rule the intake, it shouldn't matter what's in the way. if you've got a center body, such as the Mig-21 or the EE Lightning, you simply have to account for the center body as part of the area ruling. as long as you've got about 85% FSA to the point where the center body tapers to a point, you'll be ok. especially since you'll have a nice rounded inlet lip, which will draw in more air than the area of the throat. if you go to Velocity RC's website, there's a drawing that might make it a bit more clear. the drawing was done by Claus.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Oct 30, 2011, 02:16 AM
Joined Dec 2008
So are you saying that the original setup is just as good as a more open setup? That flat walled canoe makes no difference ? Have you seen the intake on one of these ?
Old Oct 30, 2011, 05:57 AM
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Bob Violet I think came up with the area rule thing.
It doesnt' appear in any textbook on hydraulics or fluid flow I've ever read.
It does make people think about the shape, and in general area ruled ducts have smooth, gentle changes in shape. They also only accelerate the air, not speed up/slow down/speed up etc.
Those things are more important than the area itself. If the duct looks bad, it probably is.
Did you get any numbers (power/thrust, speed) before ripping the duct out? That's how you'd know if you've done better or not
Odysis is offline Find More Posts by Odysis
Old Oct 30, 2011, 06:43 AM
Da' Cajun
Boogie_'s Avatar
Joined Jun 2009
Yep.
2.45" dia = 4.7 sq in (rounded numbers)
Old Oct 30, 2011, 12:53 PM
Joined Dec 2008
Ok so If I used autocad and did the intake in sections with a hot wire cutter , and squeezed the 2.45" sections into a more oval shape , would they still have the same area ? I'm no edf pro , so I have to ask .Opinions ? Anyone ?
Old Oct 30, 2011, 08:37 PM
Da' Cajun
Boogie_'s Avatar
Joined Jun 2009
If your working in autocad, won't that program tell you the area of the cross sections?
But, I think you can squish a circle into an oval and maintain the same area. ...greater minds may chime in with the correct answer.
Old Oct 30, 2011, 08:51 PM
Joined Dec 2008
So ,a 70mm Duct would be too much air for the fan ? Boogie , you mean flare the intake a little larger to account for the intake spike right ? I guess I could also make a round lip at the front of the fuse for better flow , even if it isn't scale ..Orrrr how about a servo operated intake spike on a hollow rail with the servo lead inside of the rail ? I could mount the servo right in the spike .
Old Oct 30, 2011, 08:55 PM
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Autocad will give you the area of an ellipse. I can only do 2D so my approach would be harder. The oval will work but the transition should be gentle.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Oct 30, 2011, 08:59 PM
Kevin Cox's Avatar
Joined Jan 1997
What is your reason for changing the duct? For speed are better acceleration?
Wanted Mig 21 PKDURANGO Aircraft - Electric - Jets (FS/W) 0 Aug 08, 2011 10:35 PM
Build Log Pink foam & brown paper mig-21 malakiblunt Foamies (Scratchbuilt) 6 Jul 09, 2011 01:27 PM
For Sale HET MIG-21 edf rcshirt Aircraft - Electric - Jets (FS/W) 6 Jul 07, 2011 11:16 PM
Question mig 21 tomme21 Pusher Prop Jet Models 2 Jun 23, 2011 02:10 PM
Mig-21 flops but mig-21 profile soars! Hopperfly22 Electric Ducted Fan Jet Talk 6 Jun 15, 2003 01:43 PM
