Old Mar 21, 2006, 03:43 AM
ezmo's Avatar
Finland
Joined Aug 2005
IB 1400 any tests
Hi
I noticed that there is IB1400 soon available. Anybod performed tests for it??
ezmo is offline Find More Posts by ezmo
Old Mar 21, 2006, 07:51 AM
Oakland township, Michigan
Joined Jun 2005
IB 1400 Test data
Hello,
If you go to www.cheapbatterypacks.com and look under loose cells you will see that they have posted data for the IB 1400 cells.
I hope this helps,
Teo
viva_peru is offline Find More Posts by viva_peru
Old Mar 21, 2006, 08:41 AM
ezmo's Avatar
Finland
Joined Aug 2005
thanks. I just would like to see some real user discharge graphs and "beta" testing, is it worth to buy those cells now or later.
Old Jul 26, 2006, 02:45 PM
frankswd's Avatar
Salem, OR
Joined Sep 2002
Here's what I did with my E-Meter from hyperion. I'm told By Maxamps.com that I need to charge them at 3 amps not .5 amps so I will retest but here's what I got last night. This is an eight cell pack btw
frankswd is offline Find More Posts by frankswd
Old Jul 26, 2006, 03:59 PM
Joined Jan 2001
http://www.battlepack.com/testimages/IB140025.jpg
thanks,
Steve
www.battlepack.com
sjslhill is offline Find More Posts by sjslhill
Old Jul 26, 2006, 04:11 PM
Delta, BC, Canada
Joined Oct 2003
Does anyone know the durability of the IB cells vs. GP cells? I've been abusing a set of GP 2/3A cells for over a year now (>50 cycles) and they just keep working like they're new. Are the IB in the same league or do they work well for a few flights and then start going bad after 20 cycles or so like I've seen the cheaper 2/3A cells do?
groundfx is offline Find More Posts by groundfx
Old Jul 26, 2006, 04:12 PM
Delta, BC, Canada
Joined Oct 2003
Also, one other thing... how are IB cells for charge retention? Again, I've been very impressed by the slow rate of discharge on the GPs. Are IB's as good?
Old Jul 26, 2006, 04:19 PM
frankswd's Avatar
Salem, OR
Joined Sep 2002
IB's are very good batteries, I've not had mine long, but they are being used by some of the best battery abusers in the game F5B.
Old Jul 26, 2006, 07:05 PM
Convert!
rroback's Avatar
Los Angeles, CA (UCLA)
Joined Nov 2002
I don't have any numbers, but have pushed 1400's to 30 amps, well, I had two 1400's in parralel, and pushed 60 amps ( whattmeter used for that), and they take it, and the hold voltage well.
Rhett
rroback is offline Find More Posts by rroback
Old Jul 27, 2006, 01:54 AM
frankswd's Avatar
Salem, OR
Joined Sep 2002
here's tonights test results, seems the 3 amp charging helped. still showing voltage sag. Do you have graphs to compare with these?
Discussion Any tests done yet?? witstick EJF/EPP 15 Dec 03, 2007 08:18 AM
Discussion E-Flite Power 10 & 15 any tests? Tommy D Power Systems 8 Jan 30, 2007 02:45 PM
Discussion ib 1400 battery charger help needed gsxrrob Motorcycles 10 Aug 20, 2006 11:57 PM
Discussion CBA 5cell rec. packs Traxxas 1100 / IB 1400 everydayflyer Batteries and Chargers 3 Jul 18, 2006 09:40 AM
Are IB 3800 any good when not zapped Protocooler High Performance 15 Oct 18, 2005 11:07 AM
