Old Dec 13, 2012, 08:46 PM
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Motor nomenclature: what's a 2212?
I realize this varies by supplier, but how does motor numbering work?
i.e., what does the 2212 stand for in each of these motors:
http://montorc.com/DYSA221215.aspx
http://montorc.com/DYSA221206.aspx
http://montorc.com/ipower2212Q.aspx
and what does the 06, 15 numbers mean?
I understand the KV ratings.
marhar is offline Find More Posts by marhar
Old Dec 13, 2012, 09:00 PM
tripleup05's Avatar
United States, GA, Grayson
Joined Mar 2008
I'm also interested in the answer to this.
tripleup05 is offline Find More Posts by tripleup05
Old Dec 13, 2012, 09:07 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
The 2212 most likely means 22 mm diameter x 12 mm depth, and the 6 and 15 probably refers to turns per tooth. More turns generally equate to a lower Kv. Some motors also have a designator for Kv. The nomenclature varies among manufacturers. A motor's weight, Kv and sustained current rating are more meaningful indicators of capability.
whitecrest is offline Find More Posts by whitecrest
Old Dec 13, 2012, 09:10 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
STATOR diameter and depth.... not overall diameter and length.. for a 2212 that would be ~2826 [when talking about external measurements].
As whitecrest says 6 and 12 refer to # of turns.. for Suppo.........2212/6 will be ~2200Kv, 2212/12 will be ~1100Kv, 2212/15 will be ~920Kv
2830 external equates to 2217 stator.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 14, 2012, 06:17 PM
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
That's great information, thanks.
Is there any direct correlation between the stator dimension and kvm?
Old Dec 14, 2012, 09:23 PM
Dr Kiwi's Avatar
Joined May 2003
Not really.. Kv is dependent on number of turns, winding termination (delta or wye) and number of magnet poles. I'm not a motor winder, but length of stator might be a factor????
Old Dec 14, 2012, 11:27 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
For a given turn count and wind scheme, stator height is approximately inversely proportional to Kv. If you have a motor with a Kv value of 1000 RPM/V and you double the height of its stator (changing nothing else), you'll end up at about 500Kv.
You can see this effect easily with the Suppo line: A 2212/6 has a stator height of 12mm and Kv = 2200. A 2217/6 is almost the same build (just has a thicker shaft) with a 17mm tall stator and its stated Kv value is 1500. 2200/17 = ~129, and 1500/12 = 125. Pretty close, especially given that the stated Kv values are only accurate to within a few percent of the real-world number.
C₄H₁₀ is online now Find More Posts by C₄H₁₀
Old Dec 15, 2012, 10:05 AM
Dr Kiwi's Avatar
Joined May 2003
Thanks for educating a geologist in matters electrical! Hey, at least I had a vague idea about it.
Old Dec 16, 2012, 01:38 PM
Scratch builder
USA, PA, Telford
Joined Apr 2004
Yes Doc, length does matter.
KenSt is online now Find More Posts by KenSt
Old Dec 16, 2012, 03:59 PM
Dr Kiwi's Avatar
Joined May 2003
Not so much in golf... even at 65, I can drive the ball well enough, such that my playing partners make me hit from the back tees, while they hit from the Senior's... but my short game needs work!
Old Dec 16, 2012, 05:43 PM
Harry from Atlanta, Ga.
Old Sloppy's Avatar
Buford, Georgia
Joined Sep 2006
it's not the size of the club, it's your performance that counts....
Harry
Old Sloppy is offline Find More Posts by Old Sloppy
Sold scorpion S-2212-1920 Kv brushless motor innov8tiveTech Aircraft - Electric - Power Systems (FS/W) 1 Nov 12, 2012 03:59 PM
Sold Scorpion S-2212-1920 brushless motor innov8tiveTech Aircraft - Electric - Power Systems (FS/W) 0 Oct 19, 2012 01:49 PM
Sold Scorpion S-2212-1920 brushless motor innov8tiveTech Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2012 05:31 PM
For Sale BRAND NEW DJI 30A esc's, 2212 motors, 10" and 8" props Foam boy Aircraft - Electric - Multirotor (FS/W) 10 Aug 13, 2012 03:37 PM
Found Desperately need DJI 2212 motor(s) Keddy Aircraft - Electric - Multirotor (FS/W) 2 Jul 24, 2012 09:22 AM
