Old Feb 06, 2012, 06:58 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
HK 2826 3400 KV wanting to replace the shaft so it won`t spin in endbell
This motor shaft is turned down to 2MM and i have bent all three shafts of my motors I see it has a grub screw to hold the shaft. I have taken that out and twisted and pulled but to no Avial. The Next step is to put a punch on the end and tap it out ....But since i have had a hard time getting it out i ask myself are they also Press fitting these in? some sort of special glue maybe?
Can Anyone give me some advice on how to replace it and make sure it dosn`t spin in the endbell?
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Feb 06, 2012, 07:49 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Your best bet is to press the shaft out in a vice or an arbor/drill press.... never use a punch and hammer! It is probably a tight press fit, but in case there is some glue in there, you could try heating the bell where the shaft fits to soften such glue.. heating might expand the bell a little.... and loosen it too.
When you press the new shaft in, a very tight set-screw and a bit of Loctite 638 on both screw thread and shaft/bell might hold it.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 07, 2012, 02:32 AM
kushal_22's Avatar
Kamloops
Joined Dec 2001
Thanks...Just did that and i don`t think i needed the locktite but used it anyways...I would like to find the right Length 3MM Shaft though...I ended up using the one shaft that was not bent..the motor ended up getting dirt in between the magnets and seizing. If Anyone knows how to find the replacment shafts over at HK...I have loked but am missing them or not looking in the right place..
Mal
What I am hoping for is to find a used 16/15/3 and slap that on the back end
Old Feb 07, 2012, 03:51 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Is that an inrunner? If so, throw it away and buy a replacement it is best option.
For outrunners, Head's Up RC is a good source for shafts if you can fit them yourself:
http://www.headsuprc.com/servlet/the...FTS/Categories
Strong Motors has some 3mm shafts including some with 2mm ends ground on them:
http://www.strongrcmotors.com/Shafts.htm
Here is a how to on making shafts:
http://www.rcgroups.com/forums/showthread.php?t=1240725
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 08, 2012, 08:39 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
[url]http://www.strongrcmotors.com/Shafts.htm[/url
Jack
I think you have INrunners and Outrunners swapped. As inrunners you have no end that needs to be secured as both ends spiin and all you need is a C clip at the rear end. OUTRUNNERS on the other hand need one end to be Secured and is a pain in the ass. i think your right on the trow away part though....just a outrunner
Old Feb 08, 2012, 10:02 PM
Canada
Joined Nov 2000
One can use the 3mm shafts that are universally fitted to cdrom drives/ cdplayers Or failing that use a piece of 3mm drill Or even 3mm piano wire.
The circlip groove is fairly easily cut in using a dremel cutoff wheel.
Search .. it's an Old technique.. well documented.
Yes a bit of work but still a heckuvalot easier than awaiting delivery of some overpriced (with shipping) bit of rod 'replacement'.
Bare is offline Find More Posts by Bare
Old Feb 08, 2012, 11:16 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
MMMM Cut off wheel yeahhhhh (Homer simpson kind thing)
Thanks for the "Class" i have a 3MM shaft just didn`t have the "Clip ring" which i now know how to make
Mal
Old Feb 09, 2012, 08:25 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Mal
If you need to make a "clip ring" for a 3mm shaft you can take a 2mm or 2.5mm flat washer and cut a narrow slit on one side. That can be forced down over the shaft until it drops into the groove. And it can be tightened with pliers if it is too loose.
Drilling out a wheel collar and backing up the clip with it will add some insurance against the clip coming out.
Jack
Discussion Twister CPX blades spin - won't take off (no pitch??) Marshfacev2 3D Electric Heli Flying 4 Dec 29, 2011 01:11 AM
Discussion Top rotors won't spin on Thanley56 Electric Heli Talk 0 Dec 12, 2011 08:11 PM
Help! Align Trex 250 motor/esc won't spin up sirs69 Electric Heli Talk 13 Jul 30, 2011 11:43 PM
Help! HK won't let me order a ASW28, How can I order/ship large ASW28 to states? rcchuma Sailplane Talk 1 Jun 28, 2011 04:40 PM
Discussion Custom CDR Shaft Spinning in Endbell Air Head Power Systems 0 Aug 14, 2006 02:54 PM
