Old Jul 09, 2011, 11:00 AM
Scotland UK
Joined Jan 2005
gearbox removal
How do I remove the gearbox from a Hacker B 50. Mine sounds as though it has dried up and needs a little grease. I have tried to loosen it but despite gripper gloves etc I can't move it. I have been very reluctant to grip it in a vice. Any ideas ?
sandist is offline Find More Posts by sandist
Old Jul 09, 2011, 07:51 PM
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
On B50 Gearboxes there may be a 1.5mm set screww down inside one of the mounting holes in the gearbox. This is usually marked with a small scratch on one of the holes. You would need to loosn this before trying to unscrew the gearbox form the motor.
FL62 is online now Find More Posts by FL62
Old Jul 11, 2011, 05:49 PM
Scotland UK
Joined Jan 2005
Thank you, I will have a look and hopefully will manage.
Old Jul 12, 2011, 07:49 AM
Product Manager at Hobbico
GWRIGHT's Avatar
United States
Joined May 2000
Gripper gloves probably aren't going to do it. After removing the set screw (just put a 1.5mm wrench down each hole and you'll find the one with the set screw in it), then use a pair of strap wrenches like the ones in this link. It takes quite a lot of force. Then make sure you locktite when re-installing http://www.sears.com/shc/s/p_10153_1...3&blockType=G3
GWRIGHT is offline Find More Posts by GWRIGHT
Kontronik Fun 480-33 KPG25 gearbox removal Ben Diss Power Systems 10 Jun 27, 2006 10:06 AM
himaxx planetary gearbox removal kinseyd Power Systems 2 Mar 15, 2004 09:13 PM
Astro 010 Planetary Gearbox Noise/Removal RoyceGB Power Systems 2 Jun 18, 2003 08:07 PM
TM gearbox removal/motor switch, if box is glued on??? mike93 Parkflyers 5 Jul 10, 2002 12:22 AM
Maxon gearbox removal? shbrown Electric Plane Talk 9 Jan 06, 2002 11:34 PM
