Old Mar 17, 2015, 09:07 PM
Mulder_den is offline
Find More Posts by Mulder_den
Joined Feb 2013
RC Sound module for 20$
Hi.
I've added some sounds in to my BF-109.
Everything should be less 20$
We are using 6 wav files with different engine RPM.
+ 1 file for start and 1 for shut-off...
They are should be uploaded in to root of SD card.
RPM will be taken from transmitter throttle pin.
On video you can hear that between different sound file we have small delay.
Right now I don't know how to fix it...
If you can improve this code, please share it!
Code and BF-109 Sound files are in the attachment.
More BF-109 pics are here:
http://www.rcgroups.com/forums/showt...45020&page=106
Any Arduino Nano:
http://www.ebay.com/itm/Nano-V3-0-AT...item486c105d73
Micro-SD card reader:
http://www.ebay.com/itm/Micro-SD-Sto...item5664fac3c3
Amplifier:
http://www.ebay.com/itm/TDA7297-DC-6...item486813868d
Idea was taken from here:
Proof of concept rc sound module with arduino and wav-file (0 min 38 sec)
My system:
Rc sound system, Arduino (0 min 55 sec)
Final Result:
Bf 109 sound module (1 min 38 sec)
Mulder_den is offline Find More Posts by Mulder_den
Old Mar 18, 2015, 05:57 AM
pierrotm777 is online now
Find More Posts by pierrotm777
pierrotm777's Avatar
France, Aquitaine, Villenave-d'Ornon
Joined May 2014
Very nice share that i think to try as soon as possible !!!!
Is it possible to have shematic and board circuit ?
pierrotm777 is online now Find More Posts by pierrotm777
Old Mar 18, 2015, 06:39 AM
Joined Feb 2013
Here is nothing special.
Standard wiring for micro SD module.
https://learn.adafruit.com/adafruit-...utorial/wiring
Speaker output is pin 9 -> connect to the amplifier.
RC input - pin 2 -> connect to receiver throttle out.
Old Mar 18, 2015, 01:02 PM
Joined May 2014
How to do you build the serveral wav files !
Old Mar 18, 2015, 01:36 PM
Joined May 2014
Just for info this is another very nice sound module project !
http://aeroplan.perso.sfr.fr/bruiteur_moteur.php
Old Mar 18, 2015, 08:28 PM
Joined Feb 2013
I've downloaded video from youtube and cut it in any video editor.
I took them from here:
me-109 engine starts (6 min 15 sec)
Old Mar 19, 2015, 04:42 AM
Joined May 2014
cool
Old Mar 19, 2015, 09:46 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Is the pause caused by opening a new file? if so, you could do the opens at the start and select which file to play "now" using an already-open file.
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Mar 31, 2015, 08:04 AM
ScottyWarpNine is offline
Find More Posts by ScottyWarpNine
Joined Mar 2015
I built the circuit and tried uploading the code onto my Arduino Nano V3.0, but It will not compile. It keeps giving me this error:
Arduino: 1.6.2 (Windows 7), Board: "Arduino Nano, ATmega328"
rc_sound_module_4step_plus_start_stop.ino:5:73: fatal error: TMRpcm.h: No such file or directory
compilation terminated.
Error compiling.
Even though I installed the TMRPCM Library... Any ideas?
Edit: Problem solved. I did not install the library correctly even though I followed the instructions on the TMRpcm Github page. You can avoid this issue by downloading and extracting the zip to your desktop, inside the main folder is another folder called "TMRpcm" which you need to drag and drop to the Arduino libraries folder. Probably common knowledge for most, but I figured it may be helpful for beginner programmers like myself.
ScottyWarpNine is offline Find More Posts by ScottyWarpNine
Last edited by ScottyWarpNine; Mar 31, 2015 at 09:50 AM. Reason: Fixed the problem
Old Apr 01, 2015, 08:00 PM
Joined Feb 2013
Error compiling.
Great!
Share photo/video of your plane!
Old Apr 01, 2015, 08:48 PM
Joined Feb 2013
Sound files are added in to attachments in the first post!
Old Apr 02, 2015, 03:27 AM
Joined May 2014
Cool , thanks for this share
Old Apr 02, 2015, 05:17 PM
Joined Mar 2015
I must have this wired improperly or something. I'm using an Arduino Nano board, not the uno as shown in your video. So the speaker output is pin 9, which is D6? And the Reciever signal is connected to Pin 2, which is RX?
For whatever reason, no sound is being made when I throttle up.
Old Apr 02, 2015, 07:37 PM
highspeedirt is offline
Find More Posts by highspeedirt
highspeedirt's Avatar
Joined Apr 2012
For the Nano, D9 is speaker out, D2 is Throttle input.
CS from the card reader connects to D4.
Check the Sound Files, when I downloaded them I had to rename 6 of them from 0.wav-5.wav to 1.wav-6.wav. to work correctly with the program. The startup and shutdown files are fine.
highspeedirt is offline Find More Posts by highspeedirt
Old Apr 03, 2015, 07:33 AM
Joined Feb 2013
Thanks! Sound files are reuploaded!
For Sale Lightly used Sound Module (MrRCsound) for warbirds. viperviper Aircraft - Electric - Airplanes (FS/W) 4 Apr 23, 2015 07:36 AM
Sold MrRCSound Sound System V4.1 With TT-25 For RC Planes wdy Aircraft - General - Miscellaneous (FS/W) 1 Jan 14, 2015 06:58 PM
For Sale Model Sounds Inc. ShockWave 2 sound module & speakers visioneer_one Aircraft - General - Miscellaneous (FS/W) 3 Aug 02, 2014 11:21 AM
For Sale Real sound rc module and speakers hi2nr Aircraft - Electric - Airplanes (FS/W) 2 Dec 30, 2013 10:26 AM
