Old Mar 07, 2014, 09:56 AM
FLYBOB54 is offline
Find More Posts by FLYBOB54
Closed Account
Joined Mar 2011
I have 8 more kits available PM me to order.
FLYBOB54 is offline Find More Posts by FLYBOB54
Old Mar 07, 2014, 10:32 AM
FLYBOB54 is offline
Closed Account
Joined Mar 2011
Back to the build.
Trim the tissue about 1/8" all around and glue it down, make sure to get an overlap at the wing root. Also a licked finger will help smooth down the overlaps just make sure your gluestick is non toxic if you can even buy a toxic glue stick.
Old Mar 07, 2014, 10:39 AM
FLYBOB54 is offline
Closed Account
Joined Mar 2011
The fuselage is done the same way, tack it, do one end and then the other.
Take care lining up the second side so the top and bottom stripes line up side to side. Also no overlap on the fuselage trim the tissue right to the edge.
Small parts like the stab and rudder can be done in one shot.
Old Mar 07, 2014, 11:28 AM
FLYBOB54 is offline
Closed Account
Joined Mar 2011
The top of the wingtips will need to be done separately so cover out to the last rib and cut the wingtip tissue off, be careful not to cut through the bottom tissue.
Glue all the overlaps on the wing then hold the wingtip covering in place and rub the side of a pencil along the rib. Take it off and trim to the pencil line, it will have a slight curve.
Now glue the tip covering to the rib only, let it dry a few minutes the glue it down around the edge and trim the overlap.
Nice neat trimming really shows here so take your time.
You can release the glue with a brush dipped in rubbing alcohol.
I like to let the glue stick dry overnight then a light mist of water will shrink the tissue up nice and tight.
The scissors in the photo work very well when covering with tissue.
Old Mar 07, 2014, 03:03 PM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
PM sent.
Pat Daily is offline Find More Posts by Pat Daily
Old Mar 07, 2014, 05:29 PM
turbonut is online now
Find More Posts by turbonut
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice work. cant wait to start on mine..
turbonut is online now Find More Posts by turbonut
Old Mar 10, 2014, 03:47 PM
waynek is offline
Find More Posts by waynek
waynek's Avatar
long island,new york
Joined Jul 2009
that plane is looking fantastic . I love the printed tissue covering .
waynek is offline Find More Posts by waynek
Old Mar 13, 2014, 07:47 AM
FLYBOB54 is offline
Closed Account
Joined Mar 2011
This brace did not make it onto the plan but I have another airplane that the tissue pulled the tip up when it was clear coated so I suggest adding it to your models, I used a piece of 3/32 sq.
Mine is all covered and I will post some more today.
Old Mar 13, 2014, 08:00 AM
FLYBOB54 is offline
Closed Account
Joined Mar 2011
BTW 1 kit left.
Old Mar 13, 2014, 09:00 AM
BRUTUS2238 is offline
Find More Posts by BRUTUS2238
Huge member!
BRUTUS2238's Avatar
Pawtucket R.I.
Joined May 2008
Ill take it!
If that last kit is still available,Ill take it. Ill PM you. Thanks. Bob
BRUTUS2238 is offline Find More Posts by BRUTUS2238
Old Mar 13, 2014, 09:09 AM
Pat Daily's Avatar
Joined Mar 2001
I mailed my check last Sunday. Hope you got it.
Old Mar 13, 2014, 10:26 AM
FLYBOB54 is offline
Closed Account
Joined Mar 2011
Pat your check arrived today and your kit is on the way.
Old Mar 13, 2014, 11:12 AM
FLYBOB54 is offline
Closed Account
Joined Mar 2011
Not WW1 but my next kit is getting a build thread here. http://www.rcgroups.com/forums/showt...6#post27775099
Old Mar 13, 2014, 11:33 AM
Pat Daily's Avatar
Joined Mar 2001
Can't wait to get the E-III. Nice Flybaby build.
Old Mar 14, 2014, 01:15 AM
fgroza is offline
Find More Posts by fgroza
USA, OH, cambridge
Joined Sep 2001
flybob,
how effective is the rudder at making turns without ailerons? on my quater scale i needed to cordinate rudder with ailerons in turns. have you tried wing warping on this plane?
Frank
fgroza is offline Find More Posts by fgroza
For Sale Fokker EIII laser cut kits FLYBOB54 Aircraft - Electric - Airplanes (FS/W) 28 Mar 11, 2014 08:26 PM
AerodromeRC 1/6th scale Fokker EIII and GWS powered 1/12th scale Fokker DR.1 AerodromeRC Scale Kit/Scratch Built 1 Aug 23, 2005 08:30 PM
Wattage Fokker Eindecker EIII 400 ARF. Anyone? Dampy Parkflyers 15 Sep 13, 2003 07:36 PM
Fokker EIII plan PETERRAKE Scale Kit/Scratch Built 5 Aug 24, 2003 06:06 AM
