Old Nov 13, 2013, 04:57 AM
theepicflyer is offline
Find More Posts by theepicflyer
Crasher
Joined Oct 2013
Are there any signal towers near you? They could be interfering with the radio system. This could explain why all systems do not work. GO look around. And if you have one, use those machines that check for interference on a certain frequency. I forgot what it is called.
Hope this helps
theepicflyer is offline Find More Posts by theepicflyer
Old Nov 13, 2013, 10:50 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Go to Dimension Engineering's website and read FAQ's about when you do or don't need to add a switch mode BEC device to your speed control. I use their Park BEC because it is tiny, cheap, works well, is easiest to install ( you don't need to disconnect red wire to receiver). If you buy a speed control with built in switch mode BEC circuit, read the specs and make sure it is rated to work with the number of cells and number and size of servos that you are using.
http://www.dimensionengineering.com/
E-Challenged is online now Find More Posts by E-Challenged
Old Nov 13, 2013, 05:02 PM
majorlemond is offline
Find More Posts by majorlemond
Joined Apr 2012
Excellent information guys, thanks again for your responses.
majorlemond is offline Find More Posts by majorlemond
Old Nov 13, 2013, 07:06 PM
mrittinger is offline
Find More Posts by mrittinger
ARFs make me BARF
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Wattmeter wattmeter wattmeter! You cannot be into electrics without one... You're flying blind so to speak.
Get one and test. We need real life numbers to work with. Also grab a servo amp tester, they are only about $20 US. It'll tell you what your servos are pulling when working...
Mark
mrittinger is offline Find More Posts by mrittinger
Question Testing voltage sag on a lipo finguz Batteries and Chargers 4 Sep 12, 2013 07:44 PM
Help! align T6 transmitter brown out and crashed wc_wickedclown Mini Helis 0 Mar 14, 2013 04:17 PM
Help! Am I heading for a brown out on my KC-135? kc135boomer Electric Plane Talk 9 Feb 27, 2013 12:32 PM
Discussion Major issues due to possible brown out? heinz57zuk Crash Discussion 3 Feb 03, 2013 02:13 AM
Help! 1s voltage booster and 5amp Esc, receiver browns out! Turbopropdrive Scratchbuilt Indoor and Micro Models 7 Jan 28, 2013 04:27 PM
