Old Oct 28, 2014, 07:44 PM
Dean Bird is offline
Find More Posts by Dean Bird
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
Tough weekend at the Viva Las Vegas IMAC...
I hadn't flown since the Tucson contest and got my usual 2 practice flights the weekend before the contest.
The winds were tough all weekend. The 1st round really messed with my mind. I couldn't feel any wind on the ground but I watched the plane getting blown further out each pass.
My blood sugar was so low for my 2nd round that I don't even remember the flight. Another pilot told me he saw my plane heading for the ground and wondered what was happening. I don't remember who called for me, taking off, flying, or landing. I'm told it was a good landing in the wind conditions. I vaguely remember walking around in circles trying to figure out how to tear down my plane. That's when I realized my blood sugar was low and started taking in calories.
Sunday started nice...
Name: Vegas sunrise.jpg
Description:
The Unknown had a 1/2 snap on the very first 45 upline. I'm not a good enough pilot to get a snap started and then get the sticks back to center quick enough. I've zeroed the 1/2 snap every time it's in an Unknown. At least they could put it as the 7th or 8th maneuver so I have a little fun before the zero.
The final round on Sunday was the only round I enjoyed flying. I skipped my insulin injection after eating lunch and this time I knew the wind was blowing. It was fun to fly and I was glad I didn't pack up after the Unknown.
I only felt good about one round, so I was very happy to finish 3rd out of a 6 pilot Advanced class.
Name: 2014-10 Las Vegas IMAC.JPG
Description:
While the flying in those conditions wasn't a whole lot of fun, it was great to see some pilots from Vegas that I hadn't seen in a decade. And I always enjoy some close competition with great friends.
Dean Bird is offline Find More Posts by Dean Bird
Old Oct 28, 2014, 09:11 PM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
The winner in the 7 pilot Sportsman class at the Viva Las Vegas IMAC was flying the CARF-Models 122" Extra 330SC.
I got to judge his Sunday afternoon round. It was awesome!! It had the same visible lock onto the line after each radius. I think that looks so cool.
Old Nov 08, 2014, 11:43 AM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
During flights 129 - 136 I was noticing that the flights were only pulling from one of the receiver batteries. Another pilot mentioned that happened to them. They tested the receiver batteries and one had higher resistance. The receiver pulls from whichever battery has lower resistance. The solution was to get a new set of batteries.
I ordered two new 2500 mAh A123 batteries. They are mounted high and right in the motor dome to get a higher vertical CG and to help offset the engine weight to achieve the correct lateral balance.
Description:
They are secured to the motor dome with velcro straps and 1/2" foam underneath. I stand the fuselage up in my "workshop" and you can see the velcro straps on the motor dome.
Description:
I was told 2300 mAh wouldn't be enough for the dual ignition. I had a 2500 mAh battery for the DA 200 dual ignition to replace the 2300 mAh I was using. I've had the 2500 mAh battery since I got the plane but had never installed it. I swapped it out while I was replacing the ignition batteries. The ignition battery is also installed high and on the right side of the plane.
Here is the picture looking down into the plane as it sits on the nose. The arrows point to the three batteries.
Description:
Old Nov 08, 2014, 11:45 AM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
Originally Posted by Dean Bird View Post
Plans for the next 100 flights:
1. I only had a handful of flights to work on the setup before I started flying contests. I'm going to try a further forward CG and see if the spin entries improve. That's the one part of my sequence where I don't feel in total control.
2. Mount the battery charging jacks instead of having the connectors attached to the fuselage side with Velcro. That will make charging a little more convenient.
3. Fly some more contests and have more fun flying days!!!!
While I was replacing the batteries I mounted the charging jacks.
I made a paper template of the radius of the former where I wanted to glue the lite ply.
Description:
Wrong Way RC included a piece of lite ply for the charging jacks when I ordered the charge jack extensions. It was 3/4" wide so I need that much above the line.
Description:
The fuselage former is 1" wide so I need that much below the line.
Description:
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
I grabbed a scrap of 1/8" lite ply and used the template to create the 1 3/4" tall mount.
Description:
Description:
The test fit looks good.
Description:
Old Nov 08, 2014, 11:46 AM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
There are three of the charging jack plates to mount.
Description:
I used one of them to trace the outline on the lite ply.
Description:
The Dremel router bit and an X-acto knife open up the charging jack holes easily. A 3/32" drill bit was the perfect size for the screw holes. Thin CA was used to harden all the holes.
Description:
Old Nov 08, 2014, 11:47 AM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
I used thick CA to glue the mount to the front side of the former.
Description:
It's a little tricky, but this shows the charge jack extensions from the three batteries routed to the mount.
Description:
Charging is more convenient with easy access to the charge jacks.
Description:
Old Nov 20, 2014, 06:48 PM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
My apologies to those that choose to live anywhere affected by a polar vortex...
But, dang, it's been REALLY nice in Arizona the last two weekends.
The weather has been so nice I actually prepared for the "Best in the West" IMAC contest with 4 flights the weekend before the contest instead of the usual 2 flights.
We had 5 pilots in the Advanced class. I was about 50 points behind 1st place (out of 3,000) at the end of the day Saturday.
Our Unknown Sunday morning was too funny. The wind was blowing in pretty good. All 5 of of us got together after the round and laughed about all the mistakes we made. We joked about it being a round of "who sucked the least".
I didn't make up enough on Sunday to win and ended the contest 30 points behind 1st place (out of 5,000). I got the 2nd place trophy for this contest.
Name: 2014-11 Shootout at Felix Ranch.JPG
Description:
It was a great weekend for our last contest of the season. Close competition with good friends is always a blast!!
Old Dec 05, 2014, 04:41 PM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
2014 Season Results:
Time flies when you're having fun!!
The 2014 IMAC season is over. I flew less than 100 flights this year but made it to 8 contests.
Name: 2014 IMAC Southwest Advanced Contests.JPG
Description:
I really enjoyed myself each time I went out for a few practice flights before a contest. And we had a whole lot of fun at all the contests I attended this year. My personal "Thanks" to everyone who participated this year and made it a really fun year.
IMAC counts your top 5 contests towards your Regional Points Series championship. I ended up as the Advanced Class champion for the Southwest Region this year. My "Congratulations" to all the pilots.
Name: 2014 IMAC Southwest Advanced Results.JPG
Description:
I had a blast with all the close competitions this year, whether is was competing with someone for 3rd place or 1st place.
We have an awesome bunch of pilots in the Southwest. I hope you all have a great holiday season!!
Let's have some more fun next year!!!!
Old Feb 08, 2015, 04:51 PM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
What a beautiful day today!! I hadn't flown since the contest the middle of November. Blue skies... mid 70s... winds light and variable... I forgot how much fun I have flying this plane.
I signed up for the Cactus Classic the middle of March.
Old Feb 15, 2015, 05:21 PM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
In case you want a CARF-Models Extra 330SC in the Yellow Chequer Scheme for your Real Flight simulator.
http://www.knifeedge.com/forums/down...=file&id=21293
Old Feb 21, 2015, 11:31 AM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
Some more new things for the Extra 330SC...
CARF-Models is offering two more schemes for the 122" Extra 330SC.
Swiss Scheme
Name: Swiss scheme.jpg
Description: Name: Swiss scheme bottom.jpg
Description:
Breitling Scheme
Name: Breitling scheme.jpg
Description: Name: Breitling scheme bottom.jpg
Description:
Old Apr 20, 2015, 08:41 PM
Dean Bird's Avatar
Scottsdale, AZ
Joined Feb 2008
Well, the president was in Phoenix the Friday before the Cactus Classic. All flying was grounded so I didn't get another practice day and fly that contest.
I did get to fly the last few weekends and attended a great contest in Yuma, Arizona, this weekend.
A flying buddy in my class suggested I get a practice flight on Saturday morning before the contest started. It must have been before my Diet Coke kicked in because it was horrible. I couldn't hit a snap, couldn't do the 8 point roll cleanly, and could barely get over the top of the stall turn.
I was not expecting much when the contest started. I ended up flying the sequences in the 1st round the best I can fly them.
There were two of my flying buddies in the class. I worked on the Unknown Saturday evening with one of them. We had a great time talking about where to put the maneuvers, how big to make them, where to make sure we weren't shallow on the 45 lines, and what was going to present the best.
The pilot I worked with went first. It went just as planned, he flew well, and was totally pumped at how much fun he had flying the Unknown. That was one of the coolest moments of the contest for me.
I flew my Unknown and it also went well. This plane was the superior competition setup and it made the Unknown a pleasure to fly. It tracks so straight, has so much authority in the snaps, and has so much vertical performance. BIG FUN!!
Sunday was a competitive day and all three of us won a sequence. At the end of the contest my rounds on Saturday and winning the Unknown on Sunday earned 1st place.
Name: 2015-04 Yuma IMAC Challenge.JPG
Description:
It really felt good to be flying again!!
For Sale Carf-Models Extra 330SC Red Bull 3.1 m (122 ") Dankeller Aircraft - Fuel - Airplanes (FS/W) 2 Mar 29, 2013 10:25 PM
For Sale 72" Extra 330SC quadracer Aircraft - Electric - Airplanes (FS/W) 0 Mar 29, 2013 08:56 PM
Article Hacker Models Extra 330SC Full-Fuselage EPP Plane Review Spackles94 Sport Planes 86 Mar 29, 2013 09:13 AM
Sold Carf 330sc redbull robbytaggart Aircraft - Fuel - Airplanes (FS/W) 5 Mar 24, 2013 10:05 PM
Czech HF Model, Top Model, or Icare 3.1M Duo Discus russmans Scale Sailplanes 47 Aug 10, 2008 03:57 AM
