Old Feb 19, 2013, 09:46 PM
flydiver is online now
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
Let me understand this.....you got a bunch of guys that want to do COMBAT, but don't want to build?
You do know you WILL spend substantial time RE-building them? The cheaper, the more often.
The only way around that is build one of the formidable EPP Deltas yourself. You'll still break them but less often and at least you'll know how to fix them.
Even so last time I was out I watched a dollar tree scratch build cut an EPP wing in half. Even those aren't invincible, they just break......less.
flydiver is online now Find More Posts by flydiver
Old Feb 20, 2013, 06:34 AM
JIMBOJONES is offline
Find More Posts by JIMBOJONES
JIMBOJONES's Avatar
United States, IN, Milan
Joined Feb 2009
Originally Posted by Alkaline View Post
Ok assume the budget is 65.00, what are the options?
At that price point in a RTF config, you are looking at a HobbyKing Ember knock-off or aerobatic Micro flyer. Or the Cox style knock off Sky eagle. None of which will be decent in combat
If you are willing to go with a PNF config, you could be looking at a Wing Wing, or similar flying wing.
JIMBOJONES is offline Find More Posts by JIMBOJONES
Old Feb 21, 2013, 12:31 AM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Lightweight Stryker? Blue wonder motor, 10A ESC, 450mAh 2/3-cell Lipos?
mclarkson is offline Find More Posts by mclarkson
Old Feb 21, 2013, 12:48 AM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
These are super easy/fast to build and repair.
http://shop.flitetest.com/airplane-k...eed-build-kit/
If you buy some cheap HK electronics, you can have your planes at $30 a pop and should take less than half an hour to put the foam together.
Here are some other options.
http://hobbyking.com/hobbyking/store...arehouse_.html
I think this will be a perfect candidate. I have one, it flies well and fast and is easy to repair.
Koo is offline Find More Posts by Koo
Old Feb 21, 2013, 09:58 AM
flydiver's Avatar
Joined Jan 2007
IMO anything that is tractor driven is putting a buzz saw in the business end of combat. This is fine if the intent is maximum destruction, not just a hit. We use fairly protected mid-engine planes and still get a fair amount of prop damage.
Old Feb 22, 2013, 01:24 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
That's one reason I've always thought light Strykers would make good combat planes.
Old Feb 22, 2013, 02:43 PM
flydiver's Avatar
Joined Jan 2007
They could but the biggest threat is not being hit.....it's hitting the ground afterward. Really, in combat, in terms of damage anyway, the ground is the real enemy. The Stryker has a long exposed nose. Seems you ALWAYS hit the ground nose first.
Now, I never did combat with my Stryker but the nose was the most vulnerable spot and seem to take the brunt of my flying accidents.
Delta type wings being a lot more stubby have a more robust and easily reinforced nose.
Something like the Superfly IMO would be a good candidate.
Maybe this would tempt the OP.
SuperFly RTF Services
Don't have time to build? Let us do it for you!
FWIW this is what we settled on after a number of other trials. We made them out of FFF and amazingly got a year out of them with a fair amount of repair.
Old Feb 22, 2013, 02:45 PM
Koo is offline
Koo
Koo
Koo's Avatar
Joined Mar 2012
Just get a PNP radjet. They cost $50 each and are a ton of fun to fly
Old Feb 22, 2013, 05:34 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
True enough but when you pare them down to 11oz or so, they don't have enough mass to break the nose most of the time. If they do, you can glue/tape it back on or just chop it off and sand things to a point further back.
But enough hi-jacking...
Old Apr 22, 2013, 12:50 PM
kenh3497 is offline
Find More Posts by kenh3497
Goodnight Irene
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
We are using fan fold insulation for our planes. It costs about $1.50 to build a plane. LE of the wing is 1/4 dowel and all is hot glued together. 150watt motors on 1300 MAh 3S batteries. Most guys are running HS55 servos. I think about $60 or so will put a plane in the air. It takes about 30 minutes to build a plane.
Photos in this thread. Far right top row of photos are the planes in question.
http://www.rcgroups.com/forums/showthread.php?t=1860592
Build instructions here. http://combat.eavesonline.com/fan-fo...t/construction
I'm not part of this particular club but will be flying against them soon.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old May 07, 2013, 07:52 AM
Catware is offline
Find More Posts by Catware
Joined Apr 2013
May I suggest:
Bonsai - 21$
http://www.hobbyking.com/hobbyking/s...00mm_ARF_.html
With battery, esc, motor and servo - +28$
49$ total, right under your initial budget, not rtf but It's as close as you can get... even more rtf or durable and forget the 50$ budget.
Catware is offline Find More Posts by Catware
Old May 07, 2013, 08:32 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
We use the 35" Popwings fron Nitroplanes. If you catch 'em on sale, you can get the ARF version (airframe, motor, ESC, servos, prop) for $65. Drop in a 3s 1300 mAh battery and receiver, and go fly. Not necessarily good for indoors but we're having a hoot with them. When we collide they come apart in large chunks. As long as most of the chunks are found, they go back together quickly.
Mike_Then is online now Find More Posts by Mike_Then
Discussion Looking for active rc plane club in minneapolis davidstroman USA - District VII 1 Feb 27, 2013 02:27 AM
Sold Great Planes P-47 Combat Series RTF - LPU Seattle area $125.00 gabrielisrael Aircraft - Electric - Airplanes (FS/W) 5 Jan 30, 2012 04:15 PM
Sold Force RC Air Combat Helicopter Set (2) RTF: $20.00? Roswalt Aircraft - Electric - Helis (FS/W) 2 Jun 03, 2011 06:55 AM
Sold Force RC Air Combat Helicopter Set (2) RTF: $20.00? Roswalt Aircraft - Electric - Multirotor (FS/W) 0 Jun 01, 2011 03:57 PM
