Old Jan 19, 2013, 12:31 AM
P31 is online now
P31
Find More Posts by P31
P31
United States, WA, Spanaway
Joined Dec 2011
Help!
motor connectors
I am in need of 3 female 5.5 mm plug's everything is on back order or out of stock.
Drop a PM if you can help
Gary
P31 is online now Find More Posts by P31
Old Jan 19, 2013, 06:23 AM
RayR is offline
Find More Posts by RayR
RayR's Avatar
United States, FL
Joined Aug 2006
There are 274 pairs in stock over on OSE.
http://www.offshoreelectrics.com/pro...d=ose-55bullet
RayR is offline Find More Posts by RayR
Old Jan 19, 2013, 07:13 AM
P31 is online now
P31
P31
Joined Dec 2011
Thanks Ray, I ordered 10 pair
Gary
Old Jan 19, 2013, 07:26 AM
P31 is online now
P31
P31
Joined Dec 2011
While your up, the three wire's comming off the ESC are all one color and the motor has red,wht, and green. which wire's go's where only one wire is marked motor, this a dumb question I know, But I have been using brushed motors, this is my first brussless set up
Gary
Old Jan 19, 2013, 07:39 AM
Foamaholic is online now
Find More Posts by Foamaholic
Electric since 1990
Foamaholic's Avatar
East Central Ohio, United States
Joined Jun 2004
It doesn't matter which wires go where. Switching any two wires will just reverse the motor direction.
Foamaholic is online now Find More Posts by Foamaholic
Old Jan 19, 2013, 07:43 AM
P31 is online now
P31
P31
Joined Dec 2011
So the red wire comming off the motor would connect to the wire marked motor on the esc, and the other two dont matter.
Old Jan 19, 2013, 12:24 PM
Electric since 1990
Foamaholic's Avatar
Joined Jun 2004
None of the three matter. It doesn't matter which wires connect where. If the motor turns the way you don't want, just switch any two wires and it will run the other way.
Old Jan 19, 2013, 12:58 PM
P31 is online now
P31
P31
Joined Dec 2011
Thank you guy's you've helped mucho,
Gary
Question Best way to connect motors and ESC's: Use solder or bullet connectors? 2MacGyver Multirotor Talk 25 Mar 01, 2015 07:29 PM
Help! i need some help on trying to get the right connector lazyvida DIY Electronics 3 Jan 21, 2013 01:30 PM
Question Motor Connectors and Connections? scaleviews.com Power Systems 4 Jan 05, 2013 06:33 PM
Deans 2 & 3 pin connectors and Multiplex Connectors SOLD FieldofDreamsFlyer Non R/C Items (FS/W) 1 Jan 02, 2013 01:21 PM
Question Connectors Bat - ESC Connectors ESC - Motor? panzerd18 Power Systems 5 Mar 06, 2006 11:14 AM
