Old Dec 13, 2012, 03:45 PM
Martin Irvine is online now
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
Help!
RTF Motor comparisons?
I got a number of indoor wrecks and have stripped out the equipment. I like scratch building and was puzzling over the power comparisons of my motors. I am hoping someone can rank my power systems, (motor and gearbox), so I can figure out suitable indoor projects.
E-flite Extra 300
4-Site
Vapor
Mosquito
original SU-26
T-28 Trojan
Flyzone Albatros
(I got one of the Albatros kits and still grin every time I fly it!)
Martin
Martin Irvine is online now Find More Posts by Martin Irvine
Old Dec 13, 2012, 07:53 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
There are basically 2 different HH UM micro 8.4mm motors:
The translucent white belled SU-26/Champ motor which is the lower power and the Black belled Polecat/Mosquito/T-28/Mustang/4 site/XP/E300/Corsair/Spitfire motor which is the higher power.
ALL 8.4mm Airplane motors use the same 9 tooth pinion & Spur gear/1.5mm shaft (Except for the Mosquito, which has a reverse rotation shaft on one side), but there are few different gearboxes depending on how they mount in the plane.
There are 3 different 8.4mm wire lengths, so far: Polecat/Sukhoi/Champ is the shortest, Mustang/T-28 is mid range and 4 site/Extra 300 is the longest. To put an XP motor in a Mustang or 4 site, you would have to extend the wires, though the motor is basically the same.
For 6mm motors, there are Cessna 210/Citabria motors (weakest, no plug), Vapor/Ember 2 motor (Long wires, plug, midrange power), Kyosho Hyper motor (Kyosho plug, midrange power), J-3 cub Motor (Highest 6mm power, short wires)
The Albatros uses a 7mm motor with 12000Kv, The SE5a has a 12900Kv motor and a revise gearbox and both have more power than the 6mm J-3, but slightly less than the 8.4mm Champ motor.
UNGN is offline Find More Posts by UNGN
Old Dec 13, 2012, 10:32 PM
Joined Aug 2000
That is great - just what I needed.
Martin
Old Dec 14, 2012, 07:04 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Great summary UNGN! (Hi Martin)
Petefoss is offline Find More Posts by Petefoss
Discussion Comparison of brushed motors to brushless motors zagiflyer67 Power Systems 13 Jun 12, 2010 11:31 PM
Idea Johnson 250 & Cannon motor visual comparison Lance Scratchbuilt Indoor and Micro Models 5 Feb 21, 2002 11:34 AM
Electric Motor comparison chart? dgoebel Foamies (Kits) 5 Jan 14, 2002 05:47 AM
pager motor comparisons? opualuan Scratchbuilt Indoor and Micro Models 55 Dec 28, 2001 08:14 AM
Motor Comparisons LNL Electric Plane Talk 3 Jul 26, 2001 02:26 AM
