Old Oct 30, 2010, 08:04 PM
ravenv12 is offline
Find More Posts by ravenv12
Joined Feb 2007
Dynam Hawk Sky replacement parts?? and crash :(
I'm going to have to replace my Fuselage on my Dynam Hawk Sky. I had a very bad crash today . Fuselage broke into three pieces.
if anybody knows the best place to buy replacement parts? that would be great.
p.s it's not my fault it crash, I lost all response to the airplane. If anybody knows what may have happened that would be great.
ravenv12 is offline Find More Posts by ravenv12
Old Oct 30, 2010, 09:17 PM
Xpress.. is online now
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
Sounds like you lost signal to the plane. Or did you?
As for the fuse, JUST FIX IT!!!
3 pieces is nothing. Break out the CA and glue it back together
(need to know what foam type exactly to recommend a glue)
Xpress.. is online now Find More Posts by Xpress..
Old Oct 30, 2010, 09:56 PM
ravenv12 is offline
Joined Feb 2007
No that happen yesterday when it was totally my fault . I was trying to see how good it would glide.
Today 99.9% sure it was not my fault because I had no controls.
I have some glue that came with it but does not seem to work too good.
What do you recommend? it is EPO foam.
Also if I can still recommend a good place for replacement parts that would be great
Old Oct 31, 2010, 01:17 AM
Hitec RCD CSR
Xpress..'s Avatar
Joined Oct 2007
Get yourself a Medium Regular CA, no need for foam safe materials. EPO bonds best using regular CA. BSI Insta Cure + is my personal preference.
Old Oct 31, 2010, 05:13 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Check your battery. Voltage good? Have you range checked your plane? Even if you have done it you need to do it again after you make the repairs. You should be able to get at least 100' away on the ground to get good range in the sky. Check the instructions for your transmitter/receiver to determine the proper procedure for range checking.
Check you battery connections. Good solder joints? Connectors good? What type connectors? Some are pretty bad. Deans, XT60, EC3, banana jacks mostly OK.
Last do all you flight checks at least 3 mistakes high. That way you have time to recover if something doesn't work out.
Nitroplanes lists replacement parts for your plane.
http://www.nitroplanes.com/dy8925hawksky.html
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Discussion Servos on Dynam EZ Hawk / Hawk Sky WEREE FPV Talk 2 Dec 19, 2012 06:42 PM
Discussion Learning with Dynam Hawk Sky RcFlyerTX Beginner Training Area (Aircraft-Electric) 9 Nov 21, 2012 12:49 PM
Discussion Hawk Sky flight Roel_Netherlands Beginner Training Area (Aircraft-Electric) 33 Mar 28, 2012 04:48 AM
Discussion Ez Hawk or Sky Hawk Replacement parts needed! mjc092 Nitro Planes 4 Apr 11, 2010 09:01 PM
