Old Mar 06, 2010, 03:22 PM
AtomicPunk is offline
Find More Posts by AtomicPunk
Biplanes and Helicopters
AtomicPunk's Avatar
USA, CA, Arroyo Grande
Joined Oct 2007
Aerial Video Sled
Hi Guys,
About a year ago I bought a FlyCamOne2 and enjoyed getting video from my planes. Sometimes, when we had two or three aircraft in the air at the same time, I'd get some video of them flying, but usually very brief and pretty random. We made several attempts to fly slowly and around the same orbit, but the results were less than satisfactory.
3 weeks ago, my flying buddy Bob Gaver started towing a small missile around behind his plane, which was a hoot! It got me thinking, "Why couldn't I tow a camera sled around behind my plane and get video of it flying?"
I looked around on these forums and didn't find any advice or previous videos that were similar, so I set about building one of my own. The first was an utter failure! The second showed some promise.
The video below is the second iteration, 3rd revision of the AVS.
I think that a larger block camera or HD unit could be easily towed, given correctly sized AVS and some good video could result.
Let me know what you think. If enough people are interested, I'll be happy to share build details and some of the principles I've discovered along the way.
Simon
Aerial Video Sled AVS (Towed Chase Plane) (2 min 10 sec)
AtomicPunk is offline Find More Posts by AtomicPunk
Old Mar 06, 2010, 03:55 PM
quailbird is offline
Find More Posts by quailbird
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
Pretty cool! Shat exactly is a video sled? Show us some pictures of it!
quailbird is offline Find More Posts by quailbird
Old Mar 06, 2010, 04:46 PM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
I've thought about doing the same thing but using one of those small walmart styro gliders and a keychain camera.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Mar 06, 2010, 04:52 PM
AtomicPunk's Avatar
Joined Oct 2007
You should try it! As long as the wing loadings of the two vehicles are quite close it should work.
Simon
Old Mar 06, 2010, 05:52 PM
Canadian Geek is offline
Find More Posts by Canadian Geek
Canadian Geek's Avatar
Canada, ON, Cambridge
Joined Jan 2007
That actually was pretty cool. I think maybe you should use fishing line as the tow line. That way it doesn't show up as much in the video. Not sure what strength to use though.
- Jeff
Canadian Geek is offline Find More Posts by Canadian Geek
Old Mar 06, 2010, 06:08 PM
qualcity is offline
Find More Posts by qualcity
WHOHH..You See That??
qualcity's Avatar
Aurora, Colorado
Joined Jan 2005
That was crazy cool!
qualcity is offline Find More Posts by qualcity
Old Mar 06, 2010, 06:12 PM
AtomicPunk's Avatar
Joined Oct 2007
- Jeff
Thanks, Jeff
What you see in the video is a lightweight music wire bridle, which is attached to about 10' of Fireline 10# fishing line attached to the tug. I tried it with fishing line all the way to the tug and it showed up worse under certain lighting angles. Plus it made the yaw oscillation somewhat worse.
Simon
Old Mar 06, 2010, 06:13 PM
AtomicPunk's Avatar
Joined Oct 2007
Thanks QC!
Old Mar 06, 2010, 07:57 PM
S9coldfire is offline
Find More Posts by S9coldfire
S9coldfire's Avatar
Littleton, CO
Joined Nov 2009
That's really creative! I like it.
S9coldfire is offline Find More Posts by S9coldfire
Old Mar 06, 2010, 10:01 PM
Joined Jan 2007
Originally Posted by AtomicPunk View Post
Thanks, Jeff
Simon
Ah yes, I see that in the pictures. Wow, the tow lines look so much larger in the video than in the pictures. Is that metal fishing line I see attached to the pylon? I was thinking about clear filament line but maybe that's what it is. Either way, this is one of the best, new ideas I've seen in a while. (They need more smileys, I really wanted to put a thumbs up here.)
- Jeff
Old Mar 06, 2010, 10:09 PM
Joined Jan 2007
I was just thinking, what if you attached your lines to the wings? Same fashion as you are doing but it gets the attachment points wider in order to still the oscillations. Maybe experiment with different attachment points. I do think you've got the right idea though of having two attachment points on the sled going to a single line coming from the tow plane.
- Jeff
Old Mar 06, 2010, 10:16 PM
Joined Feb 2004
I wonder if it would be possible to add gyros to it somehow to dampen the oscillations?
Old Mar 06, 2010, 11:02 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
Hi Guys,
Simon
I think that cool, I'm definitely interested.
scrape is offline Find More Posts by scrape
Old Mar 07, 2010, 02:05 AM
Vegatron75 is offline
Find More Posts by Vegatron75
Vegatron75's Avatar
Olathe, Kansas
Joined Mar 2009
Wow! Super smooth video. I like it. I've been experimenting as well. My rig is a Super cub, w/ a 2 ft glider, and key chain cam.
I'd like to build a tow plane like yours, got Directions?
Here's a video I made w/ the above rig...
Hobby Zone Super Cub towing small glider w/ onboard camera (4 min 38 sec)
Vegatron75 is offline Find More Posts by Vegatron75
Gallery Aerial 360* Spherical Panoramas and Video Beauregard Aerial Photography 26 Mar 12, 2010 03:44 AM
Discussion my first aerial video topforce 3D Flying 0 Feb 28, 2010 08:36 PM
Video Aerial video using a CX3 Stumblebee Electric Heli Talk 8 Sep 27, 2009 09:42 PM
Video Today's CX3 Aerial Video with head winds Stumblebee Electric Heli Talk 0 Aug 29, 2009 02:41 PM
Discussion First successful Aerial video with Slow Stick and Flycamone V2 mpotter187 Aerial Photography 2 Aug 23, 2009 10:08 PM
