Old Feb 11, 2010, 12:16 PM
jacktrotter is online now
Find More Posts by jacktrotter
SagittaXC
Soquel CA.
Joined Feb 2007
Question
Higgens F-20 C.G. ?
Hi everyone, I just recently got a Higgens F-20 from a fellow sloper. It has never been flown and was wondering where the C.G. should be located? I have no plans to refer to..... Thanks Jack T.
jacktrotter is online now Find More Posts by jacktrotter
Old Feb 11, 2010, 12:39 PM
Reed is offline
Find More Posts by Reed
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
The planform on those is pretty close to symmetrical - just start somewhere between 25% and 30% of the root chord and adjust from there (probably back a bit).
How heavy is it?
Reed is offline Find More Posts by Reed
Old Feb 11, 2010, 01:42 PM
matter_daddy is offline
Find More Posts by matter_daddy
matter_daddy's Avatar
Westside, Santa Cruz
Joined Mar 2006
This is directly from the manual;
"The C.G. is set 2.75-3 inches from the leading edge, adjust for your prefrence."
matter_daddy is offline Find More Posts by matter_daddy
Old Feb 11, 2010, 01:43 PM
Joined Mar 2006
If you want to swing by I can make you a photocopy of the plans. Let me know?
Old Feb 11, 2010, 01:50 PM
ian hammerton is offline
Find More Posts by ian hammerton
indeskies
ian hammerton's Avatar
Flat Leicester
Joined Jun 2005
Got mine flying at 78mm but not had a lot of air time to refine it.
If it`s too far forwards to start with you will not have enough elevator response to keep it in the air. Had mine set safely for a start but it just headed straight for the bottom of the hill and I couldn`t pull it out.
Ian.
ian hammerton is offline Find More Posts by ian hammerton
Old Feb 11, 2010, 04:49 PM
SagittaXC
Soquel CA.
Joined Feb 2007
Thanks For All The Great Info...
Thanks Guys!!! Cody I may take you up on that photocopy this weekend if your available....Jack
Old Feb 11, 2010, 04:51 PM
SagittaXC
Soquel CA.
Joined Feb 2007
C.g.
Ian I'll probably start with your 78mm recommendation...Jack
Sold Higgens F-20 SlopeRC Aircraft - Sailplanes (FS/W) 2 Jan 05, 2010 08:31 AM
Help! Cressline F-5E, F-20 C.G. location PlumberJohn Electric Ducted Fan Jet Talk 14 Sep 09, 2008 08:34 AM
Help! Need c/g for Het F-20, kid destroyed the instructions! elfwreck Electric Ducted Fan Jet Talk 7 Apr 23, 2008 08:55 PM
Higgens F-20 blivsey Aircraft - Sailplanes (FS/W) 6 Aug 12, 2004 11:59 AM
Where do I get a Higgens f-20? blivsey Slope 9 Feb 20, 2004 10:01 PM
