Old Dec 31, 2009, 08:35 PM
damiens75 is offline
Find More Posts by damiens75
Sydney, Australia
Joined Dec 2004
Trouble getting 0 pitch
Got an HK-450 and whilst I am getting better at hovering, for some reason I cant seem to get 0 pitch set at middle stick, in effect I am cheating a little and hovering below mid stick.
Despite using a pitch gauge showing it is 0 degrees at mid stick the heli lifts off before getting to mid. It is lifting off at around 1/4 - 1/3, any suggestions, perhaps I am not using the pitch gauge 100% correct.
cheers.
damiens75 is offline Find More Posts by damiens75
Old Dec 31, 2009, 08:38 PM
dze is offline
dze
Find More Posts by dze
dze
maybe not .. just set the flybar level and sight the end of the blade when the stick is at the midpoint .. the blade should look level whilst comparing to the flybar ... my experience has been you can eye-gauge it to within 1/2 a degree or so of zero. you should have the swash level (ie square with the mainshaft) for this exercise
dze is offline Find More Posts by dze
Old Dec 31, 2009, 08:56 PM
9sec240 is offline
Find More Posts by 9sec240
Advanced Heli Collector
9sec240's Avatar
USA, IL, Carol Stream
Joined Jan 2009
Turn on throttle hold and set your stick to the middle. fold your blades back like they were going into the blade holder. Rotate the blades to the front of the helicopter and then pick up the helicopter from the tail shaft and hold it hanging nose down. If the blades are at zero pitch, they will hang exactly the same way.
Zero pitch
Not zero pitch.
Try to hang the heli so the flybar and the tail boom are parallel for best results.
9sec240 is offline Find More Posts by 9sec240
Old Dec 31, 2009, 09:17 PM
Sydney, Australia
Joined Dec 2004
Thanks guys, did it by sight rather than pitch gauge, alot better now. Cheers
Old Dec 31, 2009, 11:59 PM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
You can look at my DX7 setup guide in my blog. Just click my name. Your radio may be different but the principles are the same.
Gino CP is offline Find More Posts by Gino CP
Old Jan 01, 2010, 01:50 AM
Sydney, Australia
Joined Dec 2004
I have got a Dx7 as well.
Oh well , just went for a fly at the local oval and was flying well, big gust of wind came and picked it up and I lost orientation, into the ground she went.
Busted teeth on the main gear, bent tail, bent blade shaft a few other bits and pieces bent. Oh well back to the online store
Old Jan 01, 2010, 11:05 AM
frac is offline
Find More Posts by frac
anarchist
frac's Avatar
it's not like the pitch gauges are precision instruments anyway.
more like an eyeballing assist
frac is offline Find More Posts by frac
Old Jan 04, 2010, 06:27 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Its all in the setup man:
http://www.mycoolheli.com/symetricalheadsetup.html
Melnic is offline Find More Posts by Melnic
Help! Trouble with FF9 & Pitch Curve LongChair Electric Heli Talk 2 Jan 07, 2009 07:26 AM
Help! swash plate trouble :0( help!! mrmurder1975 Coaxial Helicopters 4 Jan 05, 2008 03:04 PM
Discussion Trouble bringing Heli down (pitch problem) jon_nic Electric Heli Talk 3 Jun 26, 2007 05:13 PM
Trouble getting to ezone jhearn Electric Heli Talk 2 Nov 16, 2002 03:26 PM
Trouble getting it down rays89 Beginner Training Area (Aircraft-Electric) 6 Jun 11, 2001 01:57 PM
