Old Sep 27, 2013, 10:47 AM
SteinHolstad is offline
Find More Posts by SteinHolstad
Norway, Oppland, Jevnaker
Joined Jul 2013
Aileron, elevator, gyro sensitivity adjustment
On both the X3V and Nano CP there is a sensitivity adjustment knob. Turning it clockwise (to +) the gyro sensitivity is increased and opposite turning it anticlockwise (to-) the gyro sensitivity is decreased.
I have decent control in normal flying (not inverted that is). As I do inverted flying on the simulator I also have dared trying inverted on the Nano and X3V. I manage to fly inverted but the added worry for crashing makes the adrenalin rise. But I do not think that is the only reason for the added difficulty from the simulator to doing it on the helis.
Then I started to think about this adjusment knob. How are You folks have the the adjusment knob set for inverted flying? I have it set around middle position - maybe a touch more to minus. I do not change this as the Skyartec helis fly very nice and steady. But maybe the setting should be changed when doing inverted flying with flips and rolls?
Hope to hear from You!!
Stein Holstad
SteinHolstad is offline Find More Posts by SteinHolstad
Last edited by SteinHolstad; Sep 27, 2013 at 10:48 AM. Reason: Forgot to select email notification..
Discussion TowerPro Gyro sensitivity adjustement? Teckos Electric Heli Talk 2 Sep 29, 2009 11:29 AM
Discussion 4#3b BL Gyro sensitivity adjustment procedure energeezer Micro Helis 3 May 27, 2009 06:43 PM
Discussion TX MOD: Adjusting Aileron/Elevator EPAs and stick sensitivity on non-programmable TXs EQMOD Micro Helis 1 Jan 21, 2009 10:45 AM
Discussion Walkera 4G1 B 2.4G 4ch Newbie Gyro(Sensitivity) & Mix Adjustments on RX VRDLLC Micro Helis 3 Dec 12, 2008 07:58 PM
Any info for newbie how to adjust Elevator/Aileron? us_matrix Micro Helis 3 Jun 29, 2005 12:26 AM
