Old Jan 02, 2009, 05:55 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Question
Rudder question ...
Need help from you all.
How big a rudder should be ? and .....How much a big rudder will affect the flight of a plane ?
T.I.A.
Franky
frankyfly is offline Find More Posts by frankyfly
Old Jan 02, 2009, 06:36 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
Any particular model in mind?
I rarely use the rudder when flying, but when I do it's effect depends on the layout of the model. If the model has significant dihedral in the wing, the rudder simply banks it and turns it just like the ailerons do (some elevator needed also). With some other models the rudder simply makes the plane sideslip.
abenn is online now Find More Posts by abenn
Old Jan 02, 2009, 07:07 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Hello Abenn,
I will recycle some meat trays, this is my aim.
Any rule of thumb to follow ?
Franky
Old Jan 02, 2009, 07:51 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Average rudder/fin area should be about 8% of wing area for an aileron plane according to Andy Lennon. He has a great book if you like to do your own designs. The TLAR method works well. To small and you may run into Dutch roll where the tail wags back and forth like a fish tail. To big and you may run into spiral instability. A short tail requires more area. The opposite for a long tail moment arm.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jan 02, 2009, 09:11 AM
United States, NJ, Frenchtown
Joined Mar 2003
Build in confidence.
It really really comes down to control in a breeze during the speeds on landing and takeoff. Too little control areas, there are all kinds of weird & different types of crashes.
Too much areas, in my overdoing it, just make the SCALE SPEED planes twitchy. But I do not lose control suddenly as I get near the stall speeds.
All my scratch blue foams & GWS foams are well under 1 pound per sq ft wing loadings. That alone makes any plane much easier to control. Anyone running flat out, can pass them during landings.
I use a flat bottomed Clark Y in all scratch built foams. It starts to noticeably lower the nose & pick up speed as I glide too slow. Sort of a built in auto pilot condition. At height, it makes people wonder. Why is it doing that very slow, lower the nose & raise the nose?
Rich
cyclops2 is online now Find More Posts by cyclops2
Old Jan 02, 2009, 11:52 AM
Florida
Joined Aug 2004
Is is to your benefit to learn to use the rudder along with the elevator and ailerons. Once you start using the rudder, you will feel lost when flying a plane without rudder control. There is so much more you can do when you control pitch, roll and YAW rather than just pitch and roll axis.
Rodney is offline Find More Posts by Rodney
Old Jan 02, 2009, 12:26 PM
Joined Mar 2003
Landings in a side wind.
Are less exciting with a oversized rudder.
Old Jan 02, 2009, 01:16 PM
frankyfly's Avatar
Italy
Joined Sep 2004
Thank you all.
I found few design parameter on the web, but not much clear about the tail area distribution for the stabilizer/elevator & fin/rudder.
Flypaper can you clarify what you say about the rudder/fin area ratio.
That mean the total area (fin + rudder) must be equal to 8% of the total wing area. Correct ?
If so, how to distribute that value between the fin and the rudder ?
Franky
Old Jan 02, 2009, 01:27 PM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Hi Franky:
Yes, it's the total area of the fin and rudder. For 3D and aerobatics you would want a higher % of rudder area. For a trainer type maybe 1/2 or 1/4 of the area for rudder so the fledglings don't get into deep doo doo. For the plane you showed, more or less a sport plane, probably 50% would be fine.
Old Jan 02, 2009, 01:37 PM
WARNING: May contain spam
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
frankyfly: The plane you wish to build uses ailerons and an elevator for banked turns. No rudder is used on it.
Xpress.. is online now Find More Posts by Xpress..
Old Jan 02, 2009, 01:40 PM
frankyfly's Avatar
Italy
Joined Sep 2004
Area distribution.
Hi Franky:
Let me see if I understood what you say ....
Example : If I have a total of 200 square/cm fin/rudder area, the fin area should be 100 sq/cm end 100 sq/cm for the rudder. Is it right ?
Franky
Old Jan 02, 2009, 01:43 PM
Xpress..'s Avatar
Joined Oct 2007
^Yes, from what he is saying. However, with a plane like that, if the total rudder size is 3" long, about a 1" rudder would be sufficient. It's all really experimentation, and seeing what size of a control surface you prefer. Some like biger, more responsive controls, and some prefer softer and smaller controls.
Old Jan 02, 2009, 02:19 PM
frankyfly's Avatar
Italy
Joined Sep 2004
Thank you EX. I got it.
Can you help me a bit more to understand and interpret the following pictures.
Franky
Old Jan 02, 2009, 02:37 PM
Joined Jul 2004
V-stab and H-stab mean vertical stabiliser and horizontal stabiliser respectively. The vertical stabiliser is the "tail fin", and the horizontal stabiliser is ... the horizontal thing
So, your diagrams are showing you how big the V-stab and H-stab should be as a percentage of the wing area (similar to flypaper 2's reply), and it's then showing you how big the moving surfaces (rudder and elevators) should be as a proportion of the total V-stab and H-stab.
Old Jan 02, 2009, 08:47 PM
Xpress..'s Avatar
Joined Oct 2007
Here's a little diagram of the aircraft parts.
Alert JR 8103 Vtail/ Elev-Rudder question... Mr.Dickles Radios 3 Aug 04, 2004 11:38 AM
Slowstick Rudder question GForceStress Parkflyers 5 Oct 13, 2002 11:21 AM
E-Streak Rudder Question Goneflyin Sport Planes 5 Dec 14, 2001 05:36 PM
