Old Nov 10, 2014, 12:24 PM
Joined Nov 2014
torque 4016/500 and airboss 80A
Hi all!
I'm new to the forum, just finish build my mxs 64", with the torque 4016/500 mkII and airboss 80A, feeling the motor is slow to get rpm, anyone had problems with the Airboss 80A? It's more logical that it's the ESC that's' the problem?
Wondering to buy the CC Edge 100A, is that to much? the cc 75A is a bit to small since the motor can peak 80A for 20 sec?
Thank you in advance for answers
Sluska is offline Find More Posts by Sluska
Old Nov 10, 2014, 12:28 PM
RKevinEstes's Avatar
United States, TN, Nashville
Joined Jan 2013
Sometimes they have come to me programmed to "soft start". Run through the programing sequence and disable soft start and you should be good to go. You can find the programming manual here.
http://www.extremeflightrc.com/html/airboss.html
RKevinEstes is online now Find More Posts by RKevinEstes
Old Nov 10, 2014, 12:30 PM
can't buy vaporware
7oneWo1f's Avatar
Joined Nov 2011
I have the same combo on my 64" and love it (ariboss/4016/500 mkii). Try resetting the programming (prop off).
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Nov 10, 2014, 12:39 PM
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Yes. Reset to defaults. If it doesn't seem to fix it, try it again.
I've had one that arrived setup for 'governor mode' which wasn't a whole lot of fun to fly until I reset it.
...I've also bought a couple, for cheap... where people were having issues and "didn't feel like fooling with it" that turned out perfectly fine after a reset, too
C_Watkins is offline Find More Posts by C_Watkins
Old Nov 10, 2014, 12:51 PM
Joined Nov 2014
Thank you for all your answers, tried to reset it now, may be a bit better, and yes C_watkins, that's the issue x) i don't like stick programming x)
And also i'm i currently using zippy compact 35C battery's, they works perfect for my Logo 600 sx, so tought i would try, but is the C rating too low for the motor setup in a plane that don't use GOV ?
Old Nov 10, 2014, 09:21 PM
Pro Bro #1963
Joined Mar 2004
Don't forget to either set an idle trim or do it manually so that the motor is spinning very, very slowly at zero throttle. This is mentioned @EF and greatly improves throttle response!!
BTW.....I bet you're gonna love the 64" MXS........it is my fav! What scheme you go with?
flygilmore is offline Find More Posts by flygilmore
Sold Torque 4016/500 and airboss 80 amp esc swampflyer Aircraft - Electric - Power Systems (FS/W) 0 Aug 01, 2014 05:31 PM
Sold Torque 4016/500 V2 and Airboss 80A ESC TopShuter Aircraft - Electric - Power Systems (FS/W) 6 Oct 13, 2013 10:30 AM
Sold Torque 4016/500 V2 with Airboss 80amp ESC Neilbo4 Aircraft - Electric - Power Systems (FS/W) 9 Apr 29, 2013 05:25 PM
Sold Extreme Flight Torque 4016/500 and Airboss 80A ESC SupaTim Aircraft - Electric - Power Systems (FS/W) 5 Mar 06, 2012 11:36 AM
Wanted Airboss Elite 80A ESC and/or Torque 4016T-500 VKGT Aircraft - Electric - Power Systems (FS/W) 1 Apr 21, 2010 04:25 PM
