Old Oct 08, 2013, 12:52 PM
Joined Sep 2013
Waiting for hull and hardware, cmon Hobbyking it's paid for and processed...let's ship it......
Brushy is offline Find More Posts by Brushy
Old Oct 09, 2013, 12:57 PM
Joined Sep 2013
Today some stuff arrived from overseas...
Description: Flexshaft
Flexshaft 3/16"
Description: ESC
Birdie 200A ESC
Description: Stinger
Stingerdrive with propeller, too bad that the propshaft was bent where the flex
shaft will be inserted, and not that impressed with the propeller that came with
the drive.
Description: Rudder
Rudder with following measures, blade 150mm and the part that holds the rudder is 75mm. Surface is kinda rough on this rudder.
Description: Turnfins
Turnfins also rough on surface.
Description: BEC
3A BEC with inbuilt AUX controlled ON/OFF switch.
Will need advice how to set the flexshaft and rudder when the hull arrives.
Old Oct 13, 2013, 11:54 AM
Joined Sep 2013
Update: Propellershaft is now unbent , and in working order. But still there is the issue with orders getting stuck at warehouse.
Also is it half as warm today if I compare with yesterday.
Will try to get hull and hardware up and running before winter strikes.
/Brushy
Old Oct 15, 2013, 03:28 PM
Joined Sep 2013
Hi everyone
Some more hardware arrived from OSE today, with a new leopard 4082
1600 kv.
But no hull so far, still stuck at warehouse and support keeps excusing for
heavy orderload
/Brushy
Old Oct 25, 2013, 03:00 PM
Joined Sep 2013
At last..... hull has arrived!
Description:
Osprey hull, quality seems quite good.
Description:
Osprey this side towards water
Description:
Inside waiting for other hardware.
what do you think ? Just need to take time off from work to assemble it. Work takes too much time from funstuff.
Old Oct 28, 2013, 08:34 AM
Australia, VIC, Blackburn North
Joined Feb 2011
Get to work!!
mozzyrocks is offline Find More Posts by mozzyrocks
Old Oct 28, 2013, 11:54 AM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Yeah - don't let work get in the way of having fun!
cyberhoops is offline Find More Posts by cyberhoops
Old Oct 28, 2013, 06:16 PM
Joined Sep 2013
Originally Posted by mozzyrocks View Post
Get to work!!
Hehe unfortunately work is needed to have fun :/ but I will get cranking
with assembly.
Question how far from bottom do I have to mount stingerdrive?
And how far from center of stingerdrive to the right am I supposed to mount rudder? 2 1/2" off center ? Or is it more/less ?
Brushy
Old Nov 28, 2013, 03:33 PM
Joined Sep 2013
Decided to testmount motor today...
Description:
Is there any issues that flexaxle is only 220mm tip to tip?
Current setup places motor 120 mm from transom.
Inputs needed..thankyou.
Old Dec 02, 2013, 02:22 PM
Joined Sep 2013
Help with above questions needed....
I'm also gonna go with no teflonliner just flexaxle, 1/4 inch brasstube and grease. With new setup .187 axle , tube and stingerdrive I will be able to remove axle for easy greasing after every run.
Also a new rudder with 2 1/4 inch setback and dual waterpickups is on the way.
Brushy
Discussion DIY projekter - Projekter udviklet af Dennis SpookiePower DK FPV 267 Aug 20, 2014 02:33 AM
Discussion CAD Projekt - Gimbal GoPro3, BLDC pirzol Multirotor Talk 0 Jul 12, 2013 07:46 PM
Gallery Arado Projekt jimsky Your Plane Photos 0 Jul 23, 2004 08:56 PM
Gallery Arado Projekt jimsky Your Plane Photos 0 Jul 23, 2004 08:55 PM
