Old Jul 30, 2008, 12:15 PM
Joined Jan 2004
Question
Simple 400 Similar Plane?
Anyone know of a plane that flys like an Ace Simple 400 ?
I had 2 short flights on my Simple 400 before the wing had an accident with a closing door. I really liked the way it flew but would like to check out options for a better looking machine.
Oh, and preferably under $70--willing to build....
Thanks.
Time Pilot is offline Find More Posts by Time Pilot
Old Jul 30, 2008, 01:08 PM
Joined Feb 2000
Jump in and scratch build. A plane like that isn't hard to design and build and its much more satisfying.
I built the plane in the attached pic, its Speed 280 powered and a little smaller. Balsa box fuse, slab empenage, and simple built up wing. Less than $20 in balsa.
strouse is offline Find More Posts by strouse
Old Jul 30, 2008, 03:11 PM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
How was yours powered? If you're willing to use an inexpensive outrunner, the Mountain Models EZ series airplanes are not far away in concept from the old Ace Simple Series (but with a few neat new tricks). The EZ Scout is probably the closest one.
If you really want to use a Speed 400....perhaps the prior answer is a better one.
BEC is offline Find More Posts by BEC
Old Jul 30, 2008, 06:46 PM
Joined Jan 2004
Strouse,
Still having the plans, I considered doing just that and modifying the wing somewhat to give it a slightly thinner profile. That is definitely a possibility. You did a nice job on that plane, BTW.
BEC,
I looked at those models and I'm not sure they'd fly the same as the Simple 400--just curious if you've flown the Simple 400?
I have a Great Planes Slinger which I like--everything but the prop whine. The Simple 400 flew a little like that, good glide, fairly fast, tracks well, but does it all quietly.
I'm powering the Simple 400 brushed, but that's not a necessity. I just did that because there was supposed to be Speed 400 pylon racing in our area which kind of fell through.
I'm close to full throttle flying it (80 watts: 7cells Nimh, 4.75x4.75 APC prop, GWS EM400) so a brushless motor w/lipos would be a good blend. Half throttle for zipping around the sky and full for all that other crazy stuff.
Wanted simple 400 plane val1756 Aircraft - Electric - Airplanes (FS/W) 1 Oct 08, 2007 11:39 AM
JKA e-plane or Simple 400? DrZiplok Parkflyers 11 May 15, 2004 07:16 AM
Can I slope this kind of plane? WM combat plane or ACE simple 400?? Magna Slope 3 Oct 20, 2003 10:27 PM
What is the best overall flying 400 speed plane available Jaymz007 Electric Plane Talk 9 Jul 17, 2001 01:53 PM
Spare simple 400 wings? KMKAZE Electric Plane Talk 2 Jul 12, 2001 01:21 AM
