Old Sep 11, 2006, 08:56 PM
Flying Extraordinaire
United States, FL, Fort Myers
Joined May 2006
Measuring the pitch of a spur gear??
How does one accurately measure the pitch of a spur gear? I have a dc motor with a gear on it and want to get a corresponding belt gear that matches. I went to https://sdp-si.com/ but can't accurately measure the pitch to match to the correct gear belt.
Any ideas? suggestions?
Fossil1977 is offline Find More Posts by Fossil1977
Old Sep 11, 2006, 09:21 PM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
If you know who made the spur gear, ask them.
Or find a matching gear whose specs are known.
Sparky Paul is online now Find More Posts by Sparky Paul
Old Sep 12, 2006, 12:53 AM
Australia, NSW, Sydney
Joined Feb 2003
If it's for a toothed belt they only come in discrete pitches, 1/4, 3/8, 1/2 etc. So if you measure the distance between peaks you should be able to work out which one it is. The pitch diameter is taken below the outside diameter of the pulleys, but measuring on the peaks should get you close enough.
Graham.
Salto is offline Find More Posts by Salto
Old Sep 12, 2006, 03:58 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Get some plasticene and roll the wheel over it. Count the distance and the toothpmarks. Do the Math.
Old Sep 12, 2006, 01:42 PM
Joined May 2006
What is plasticene? how hard would it be to make my own belt gear?? If I used putty as you say and roll the gear over it then I would have a mold correct? can you buy liquid rubber to make your own??
thanks
Old Sep 12, 2006, 01:59 PM
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
Measure the diameter of the gear across the peaks of the teeth. Measure the diameter from valley to valley. Take the average of these two numbers - it will be close enough to the "pitch diameter" for our purposes. Count the number of teeth and divide by the "pitch diameter". Round to the nearest whole digit and you'll have the pitch.
Plasticine is a form of clay similar to the kids modeling clay (not PlayDough). It is what the Aardman studio used to create the characters in "Wallace and Grommit", "Chicken Run" and the rest of their clay-mation films.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Sep 12, 2006, 03:18 PM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I too thought of making my own belts..sadly what you need is a fairly complex composite of kevlar and rubber..best to just buy them.
Moulding the cogs may not be so far fetched tho.
Old Sep 13, 2006, 01:13 PM
I like the violent stuff!
Costa Mesa, CA
Vintage is on the right track. At work I roll it over a piece of carbon paper measure the distance between points and do the math.
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
GP DG600 Spur Gear LJH Sport Planes 9 Dec 13, 2001 03:11 PM
Pinion and Spur gear alignment kenny_dilger Electric Plane Talk 6 Dec 06, 2001 03:39 AM
10 tooth/48 pitch pinion gear, where at ? William A Sport Planes 7 Sep 28, 2001 12:52 PM
Cheap Spur Gear Puller - Need One? hoppy Power Systems 0 Jun 27, 2001 08:19 PM
spur gear slipping t-turley Parkflyers 3 Jun 18, 2001 05:52 AM
