Old Dec 26, 2004, 03:24 PM
v3611504's Avatar
Richmond VA
Joined Feb 2004
Co-Pilot with rudder control????
I just got the Co-Pilot and wanted to use this with my Slow Stick for AP so my photos will come out better. Just wanted to ask you guys a few questions about this device. Is it a way that you can use the co-pilot for rudder control instead of ailerons? I see that the co-pilot only has inputs for elevator and ailerons. I have searched around and found a few guys using the co-pilot on the Slow Stick but wondered how you got it to work without aileron control. Do you have to install ailerons on the Slow Stick or is it a way that you can use the rudder on the co-pilot?
v3611504 is offline Find More Posts by v3611504
Old Dec 26, 2004, 04:09 PM
Trying to defy gravity...
jimsky's Avatar
USA, NY, East Northport
Joined Dec 2003
My AP Stick with CoPilot uses standard rudder and elevator control. I just plugged the elevator servo into the "Elevator" (up/down) channel, and the rudder servo into the "Aileron" (right/left) channel .... and it worked just fine.
I love my CoPilot, I wouldn't fly AP without one.
Jimsky
jimsky is offline Find More Posts by jimsky
Old Dec 26, 2004, 05:35 PM
My three sons...
Beauregard's Avatar
Steamboat Springs Co.
Joined Nov 2004
JimSky,
What copilot do you use and where can I get one?
Beauregard
Beauregard is offline Find More Posts by Beauregard
Old Dec 26, 2004, 05:46 PM
jimsky's Avatar
Joined Dec 2003
I'm flying an FMA CoPilot, it uses four infrared sensors to determine the horizon line. Earth is "hot" the sky is "cool", IR wise. It "sees" the horizon front/back and left/right and adjust the rudder and elevator to keep the plane level whenever you let go of the stick. It really works quite well.
Go to:
https://www.fmadirect.com/site/home.htm
and do a search on "COPILOT". There are two systems, I'm using the less expensive $99 one in which you use your exsisting receiver.
I just can't say enough good things about device. Level horizons on every photo, perfect landings everytime...I love this gadget.
Jimsky
Old Dec 26, 2004, 06:05 PM
v3611504's Avatar
Richmond VA
Joined Feb 2004
Thanks jimsky for your info. I will hook it up....
Sold FMA FS8 Co-Pilot with Vertical and Computer Interface plasmaman Aircraft - General - Radio Equipment (FS/W) 0 Dec 21, 2005 09:56 PM
FS FMA Co-Pilot with FS8 Sensor. Flying Weasle Aircraft - Electric - Airplanes (FS/W) 3 Sep 29, 2004 11:09 PM
FMA Co-Pilot with which other Gyro, for the Corona ? Patrick Plawner Electric Heli Talk 12 Sep 29, 2003 09:18 AM
