Old Today, 07:34 AM
chuck
Joined Sep 2013
motor cutting out
I could use some expert help. Let me give details first...aquastar t20 motor, aquastar 200a esc, castle 10a bec, spektrum dx5 with ar610 receiver, 2 traxxas 5000mah, 25c 11.1 volt lipos. I have power to receiver, power to esc. At neutral theesc beeps once and is ready to go. When I give throttle, it runs fine for about 3 to 5 seconds, then cuts out...I can go back to neutral and get it to run again until it cuts out again in 3 seconds. Motor and esc never get above room temp even after repeating this several times. Any ideas? Suggestions? Hopefully its just a simple fix and I am being boneheaded! Thank you!
cwurst is online now Find More Posts by cwurst
Old Today, 08:00 AM
Kid at heart..
United States, TX, Houston
Joined Apr 2014
I don't know what is causing it, but have you calibrated your remote throttle to the ESC?
hangtheman is online now Find More Posts by hangtheman
Old Today, 08:15 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Chuck,
How are you using this motor, in Y or D wind?
How are the two Lipo's connected, in series, or in parallel?
What boat are you powering and what size and pitch prop is used?
Depending on thew load and the configuration, it's very well possible the 25C packs can't deliver the current for the motor, which causes the ESC to shut down.
We need more info to make an accurate guestimate...
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Today, 09:50 AM
chuck
Joined Sep 2013
Not quite sure how to properly calibrate tx to esc. As for your questions, Jan, batteries are in line (for higher power) and the motor is not hooked up to drive shaft. Motor is rigged for 730kv. Btw... boat is 48", 20 lbs. ! But I dont think these are in play yet because of drive not hooked up.
Discussion One motor keeps cutting out - spectacular crash Jerry12345 Multirotor Talk 8 Apr 25, 2014 10:44 AM
Help! 2216 900kvs T-Motors cutting out in full throttle manual mode nesal Multirotor Talk 2 Feb 22, 2014 06:36 PM
Help! Motor slowing and cutting out Bubblehead21 Power Systems 5 Jan 03, 2014 10:32 AM
Discussion Two motor system, one cutting out boaterguy Power Systems 8 Dec 27, 2013 09:05 PM
Discussion Quadcopter - Motor Cutting Out squishio2 Scratchbuilt Multirotors 2 Oct 10, 2013 10:29 AM
