Old Sep 21, 2014, 05:00 PM
Joined Dec 2013
Aurora elevator out of center by a mile
Hi all,
I run into a strange problem using my Aurora 9: my elevator neutral position seems to be way off, about a quarter of the total stick travel!
It's visible in the dual rate screens as well as in the servo monitor screen as shown in the attached pictures.
Also (as expected) in the stick direction where the offset is, there is only one quarter travel left. Programming exponential does use the true center of the stick, so when using negative percentages the travel around the true center does flatten. Trims are neutral.
I have noticed this both in a flying wing configuration (a vintage Robbe Geier electric glider) and also in my Graupner Starlet 2400. Both are programmed straightforward with dual rate being about the most complex feature used.
What is the cause of this? Is my elevator stick in need of calibration? Or is there anything wrong in the programming?
Any help or advice is appreciated.
regards, Dik
dikdexta is offline Find More Posts by dikdexta
Discussion DX 9 elevator stick center is OFF center! doehunter Radios 5 Sep 16, 2014 10:15 AM
Discussion How can I mechanically center the elevator stick on DX8? LEORITY Radios 9 Jul 04, 2014 10:15 AM
Help! Flap to elevator compensation curve with Aurora 9 James P. Loughra Radios 0 Jul 01, 2014 04:22 PM
Discussion 5 mile range FPV plane... Help an FPV noob out. Dcope17 FPV Talk 10 Jun 05, 2014 01:56 AM
Discussion Elevator brown out ChopperNZ Eagle Tree Systems 2 Jan 13, 2014 08:23 AM
